Urgent help needed, stranded!
Discussion in 'Maintenance' started by martinowen, Aug 11, 2012.
  1. martinowen
    Battery died at asda so I put jump leads from car to bike and now I have no power to the dash at all !! Have I blown a fuse? Where is that fuse located etc?
  2. Jamiestrada
    5 amp fuse located just behind battery, in black box for dash.have you got any lights ? Hope you get home ok matey
  3. martinowen
    Thanks mate I will give it a go, fingers crossed it will fix it
  4. martinowen
    Fuses were ok but connections were a bit furry all cleaned up and now home, just very sweaty as stood around hours in leathers! Time for a shower
  5. Jamiestrada
    Glad your back ok mate, gutting when you get stranded, my PCV took a dump had to push bike miles to a garage then strip it down in there forecourt, got home in the end but don't expect things like that to happen do you !
  6. IcarusGreen
    IcarusGreen Elite Member
    Yesterday when I met up with Remal I had to strip my starter switch down to get my bike to run as it fooked up again. It's £55 for a new one WTF!
  7. martinowen
    Rip off that can u bodge another switch in ?
  8. Jonny fireblade
    Jonny fireblade Active Member
    Thought hondas were meant to be reliable
  9. Muffking
    I guess it wouldn't bump start? Ive had to bump start on my own before and its ok as long as you can get enough speed up.
  10. ray
    ray Well-Known Member
    Bump started mine once, the dash lit up like a christmas tree with all the warning lights.
    Obviously scared the life out of me as I thought I may have fried the ECU or something.
  11. Hudson
    Hudson Active Member
    Blood hell pal, hope it all works out ok, i thought jump starting a bike with a car was frowned upon or is this just urban myth ?
  12. IcarusGreen
    No, I've tried to fix it but it's fubard! Just wondering it they are the same switch on the 08 onwards as there's on on ebay for £30,
  13. martinowen
    Wouldn't bump as fuel pump wasnt even priming up
  14. martinowen
    Not supposed too but was desperate, I think it's something to do with difference in amps, turned out to just to needed some contact cleaner in the end
