Tyre Pressures for my 954 Blade ?
Discussion in 'Other Bikes' started by Hudson, Aug 15, 2012.
  1. Hudson
    Hudson Active Member
    Can't seem to find one answer to this...... my rear tyre is a 190/50 ZR17 and the front is a 120/70 ZR17.
    TA
  2. lee711
    lee711 Active Member
    Can't see em being any different to others so i'd say 38f/42r as standard for the road, although i like 36/38 just my preference.
  3. GappySmeg
    GappySmeg Well-Known Member
    One thing I've learnt recently, is that tyre pressures are as personal as suspension settings.
    I always used to stick religiously to 38/42... but following encouragement from a mate, I have been dropping them a tad, and generally having an experiment... found that I much prefer 36/38... my mate runs 34/34, but then he is a couple of stone lighter than me.
  4. kpone
    The book says 36/42, but like Gappy says, it's very suck it and see.
  5. Hudson
    Cheers guys, i will check what they are and go from there, it rides ok (still getting used to how damm fast it is), but i know how important have the correct pressures are.
  6. kpone
    Find someone who will personalise you suspension set up for you Hudson. Cost you between £50 and £75 and it'll give you a much better feel of what the different tyre pressures will do for you.
    I've got a PDF workshop manual for the 954 if you want a copy. PM me somewhere to post it to.
  7. BoroRich
    BoroRich Elite Member
    I've always run the manufacturer's recommendation of 36/42 but recently I've lowered it a bit to 36/38 and seem to prefer it.
  8. Hudson
    Thanks for that, I have already had the suspension sorted. I bought an Ohlins rear shock and had it serviced, fitted and set up by KAIS, at the same time i also got them to set up the front shocks after they had been sorted with new fork oil. It does ride very nice already but i always like to make sure everything is right.
