Clutch adjustment on RR7
Discussion in 'Maintenance' started by GappySmeg, Sep 3, 2012.
  1. GappySmeg
    GappySmeg Well-Known Member
    Can the biting point be adjusted on an RR7?
    I.e. on cable-operated clutches I could turn the adjusters to move the biting point in relation to the lever travel, as I like the biting range to be smack-bang in the middle of the lever travel.
    Can the same be done on a hydraulically-operated clutch?
  2. JM1
    JM1 Active Member
    I don't think so, although I could be wrong.
  3. scooby
    scooby Elite Member
    no they cant.
  4. arthurbikemad
  5. Shameless
    Shameless Active Member
    Change the fluid, if its still crap check the slave cylinder.
  6. Iain
    Iain Active Member
    Does the 07 bike not come with an adjustable clutch lever, the same as the front brake, my 04 bike does? Is that not the same moving a cable clucth?
  7. GappySmeg
    Cheers for the replies all... thought as much.
    Yes but that just adjusts the reach... I want to adjust the bite within a given reach. Having looked about the only thing you can do is shorten then master cylinder push rod or the clutch slave cylinder push rod... sounds like too much effort.
  8. raphael
    kin ell fella has that been used?? just that little bit of carbon and sprocket gets me dribbling ,very nice
  9. arthurbikemad
    That's durbahns but I like mine clean too....lol and yeah I use it but like to keep the old girl clean, I have Brembo RCS clutch slave with Brembo low drag levers, more adjustment than you can poke a stick at....lol RCS is 19-18/20 super easy to pull on 18!
    Same shot of my bike for you....lol
    #9 arthurbikemad, Sep 4, 2012
  10. raphael
    That's porn!! Quality fella love it
  11. arthurbikemad
    Cheers mate.. :)
    Just noticed that the iPad has learned how to swear.....pmsl, it did not get that from me I never swear....lol much.....lol
    #11 arthurbikemad, Sep 4, 2012
  12. uselesshippy
    uselesshippy Active Member
    try changing the clutch slave to a STM one, got mine off quay garage when they were breaking the old stobart bike.
