Which bulbs
Discussion in 'General 1000RR Discussion' started by timmy twoshoes, Sep 9, 2012.
  1. timmy twoshoes
    Hi all, my front lights seem dull ! I have H7 bulbs but which are the best ones ? Xenon 55w or 100w though I know the 100w's arent legal. Or are the gas filled ones better ? Bright white , blue/white such a choice
  2. kpone
    Weapon of choice if it's just a bulb change you're looking at is Osram Nightbreakers Timmy. Have a word with Sideways.
  3. phantomx0_1
    phantomx0_1 Active Member
    100w will melt stuff! Do a HID conversion!
  4. Muffking
    Or you can stick your high beam on during the daytime. Instant twin headlights :)
  5. phantom
    phantom Active Member
    +1 for osram nightbreakers
    or
    philips x-treme
  6. samuk
    samuk Well-Known Member
    i would be worried about doing that..as it may dazzle the car in front or something and the other driver may react in an unexpected way..
  7. Givover
    I was walking the dog last night and a Triumph 675 came down the road with what looked like LED (Ducati type lights) very nice indeed.
  8. timmy twoshoes
    Just out of interest Are all 3 bulbs the same 55w ? Been looking on eBay and a lot say dipped beam only
  9. Dave V
    Dave V Elite Member
    I've got HID's on both bikes, they are awesome.
    I have heard that this is now an MOT fail so was thinking of putting the standard bulbs back In, anyone know for sure if that's the case?
  10. kpone
    On the 954 all three are the same bulb mate, 55w H7.
  11. timmy twoshoes
    Thanks to all for your comments. Do you have to buy a conversion kit for HID bulbs how easy is it to install ?
    Or can you just put bulbs in :)
  12. Dave V
    Dave V Elite Member
    Conversion kit, easy to fit as plug and play. Hardest part is trying to find somewhere to put the ballast, depending on bike. 929, real easy, 10 plate was more challenging.
  13. timmy twoshoes
    Mines a 954 so should be fairly easy as Honda didn't change that much from 929 - what's the ballast ?
  14. phantom
    a small metal box sometimes with cooling fins just
    bigger than a cigarette box.
    just heard to stear clear of the ones that need a relay
    wired as they have been blowing on owners on the audi
    forums after a year of use and frying elements in the dash
    and ecu's :s
  15. Dave V
    Dave V Elite Member
    When I get five minutes I'll PM you the link for the ones I and loads my pals use, been on the 10 and the 929 for a couple of years with no issues. They have got the in line starter and the ballast is nice and small.
  16. timmy twoshoes
    Many thanks for that. Now I've sorted the brake issue out I don't want to bugger anything else up lol. Would be just my luck to burn the wire system out
    Regards to all for the info and heads up on parts to use or not.
    Tim
  17. Remal
    right old thread but nor worth me starting another
    While I have the bike in bits I have found out the bulbs are H& for the 2011 blade? I hope this is right
    Also any further suggestion on the bulbs. May as well upgrade them while I have them off
    Any Suggestions
  18. ColinBR
  19. kpone
    If the ampersand is the shifted 7 on your keyboard and you don't want to go down the HIDS route, I'd still recommend Osram NightBreakers as straight replacement. Sideways sells them.
  20. Remal
    I really just want a straight replacement. I find the light very good compared to my Speed triple lights and again may as well upgrade while I have the bike in bits again
