Best Place to mount a Power Commander 5
Discussion in 'Mods, Upgrades, Accessories and Products' started by BladeRR8, Sep 14, 2012.
  1. BladeRR8
    BladeRR8 Active Member
    Thinking of getting a power commnader 5 for my RR8 and was wondering where is the the best place to fit it ???? Ideally I would like to keep under the pillion seat free for carrying wallet, phone etc..... is there any other places on the bike people have managed to mount a power commander ?
  2. JM1
    JM1 Active Member
    Under the pillion seat or under the rider seat next to the battery if you have replaced it with a small Li-ion one.
    N.B. Under pillion seat gives easiest access for changing maps.
  3. Si.
    under the seat Steve.
  4. BlackDevil
    Pcv
    Under the rear seat.
  5. JM1
    JM1 Active Member
    Mine is same place but in a small padded tool kit bag. Not fixed down so just did that to avoid it clattering around, probably not needed though
  6. BladeRR8
    Cheers for the replies.
    The battery box with a smaller batttery installed is a very good idea
  7. BladeRR8
    Are people running custom maps, standard downloaded maps or autotune ???? all thoughts and opinions welcome.
  8. JM1
    JM1 Active Member
    I'm sure everyone will appear and tell you that a custom map is critical, but I'm using a downloaded map and couldn't be happier with it (I've had custom maps on other bikes, but I don't feel the need at all with this bike and map).
  9. phantom
    phantom Active Member
    I'm the same as JM1, using a downloaded map.
    tired a couple of different maps from various sites and found
    the PC download one for my exhaust felt the best.
    going to get a dyno run to see how it looks and if it isnt
    too far out I wont bother with a custom map.
  10. ams
    ams Active Member
    Put mine under pillion and got a custom dyno
  11. BladeRR8
    JM1 & Phantom what exhaust / air filter combo are you guys running ? Did you download direct from Dynojet ?
  12. BlackDevil
    Custom maps....
  13. phantom
    have the yoshi R77 without baffle, standard filter and o2 bypass
    downloaded from dynojet website :)
  14. ray
    ray Well-Known Member
    Tucked away under the pillion seat on my RR7.
    Also running a map from Dynojet's website, but I want to get two custom maps made up as I have a toggle switch fitted (baffle in/baffle out).
  15. JM1
    JM1 Active Member
    Leo Vince can (not GP Pro), O2 sensor eliminator & Euro map from DJ website for that can with baffle out
