2012 Fireblade 1000RR - Fuel Reserve
Discussion in 'General 1000RR Discussion' started by venomzn, Sep 24, 2012.
  1. venomzn
    venomzn New Member
    Hey guys
    Just wandering how many litres there is left when the petrol light comes on?
    I see a counter starts counting and am i correct in saying it starts at 0.1 litre?
    Im a bit confused with this, if someone could clear this up for me would be greatly appreciated.
  2. cbr1
    cbr1 Active Member
    when my light comes on i work on 20miles to get some petrol in? after that i just think o shit this is going to be some push:(
  3. thezipsteruk
    thezipsteruk Elite Member
    If it is the same as the 2011 model, it counts up. By reading the manual it states that the 11 model has .77 litres so Im working on the theory that .7 is Danger time.
    furthest Ive panic'd with was 0.5 so far
  4. fez.57
    fez.57 Well-Known Member
    i would agree that 0.7 is about as far as i would dare push it
  5. lee711
    lee711 Active Member
    3.7 gallon tank, so after 3 gallon the light comes on then counts up in .1 .2 .3 and so on until .7 then its time to push .. :eek:
  6. IcarusGreen
    IcarusGreen Elite Member
    The light to me means pull in at next station! but I do ride an rr-04
  7. SIDEWAYS
    SIDEWAYS Senior Member
    0.6 is my limit. If you don't push it to a petrol station when u run dry and park it up.It may not be there when you come back.
  8. venomzn
    venomzn New Member
    Thanks so much guys.
  9. samd1985
    samd1985 Active Member
    I have the 2012 model also. it counts up in 10ths of a litre used since going into reserve. it will flash at a faster rate once you get to 1.0. With a brimmed tank it lights up once 13 litres have been used, with the full tank capacity being 17.7. So far i've managed to get it flashing 3.5 at me... I was a long way from a petrol station and started to panic a bit i must say! I squeezed 17 litres in when i finally filled up!
    Sam
  10. venomzn
    venomzn New Member
    Thanks bud, so would you say its safe to run till it reads 3.0? which should leave 1 litre spare if i fill up at 3.0?
  11. ColinBR
    Can I ask why you even bother to run it as low?
    Why not fill it up sooner and not take the risk, or is that not possible.?
  12. venomzn
    venomzn New Member
    No reason, I am just curious so in the event i do run low I know approx how many litres I have left, good thing to know
  13. ColinBR
    Lol. Suppose it gives a little piece of mind then ;)
  14. samd1985
    I would say from my own experience that yes, it's fine to run it to 3.0 however I wouldn't advise you to do so if you can help it...! In the event of being stuck without a fuel stop it should give you some peace of mind. I will add though that the fuel gauge isn't perfect - I find that when filling up I can normally put own an extra half litre (when in the reserve) compared to what the readout tells me I've used, and that's with filling up to the exact same point each time. Something worth checking on yours, then you'll know with some certainty just how little you really have left during the countdown stage.
    Sam
  15. wedgiewolves#223
    wedgiewolves#223 God Like
    Im glad i come across this thread i was bloody baffled why it was flashing 0.0 at me when light came on lol . Also does it take a while after filling up on the 12 blade before the light goes back off ?:confused:
  16. callumw
    callumw Active Member
    Does it flash Litres or Gallons?
    I set my computer on my 08-11 to monitor mpg rather than mpl and it takes miles n miles to count up each tenth.
    @Wedgie. Yes the light still stays on for a bit before it registers that you got more motion lotion
  17. JM1
    JM1 Active Member
    Depends on whether you have the clocks set to KM or miles I think.
    Mine got to 0.7 gallons before running dry.
  18. venomzn
    venomzn New Member
    Hey
    Yeh it does take a little while for the petrol light to go off after filling up, i also noticed this when i first got my blade. nothing to worry about.
