Multiple monitor setups
Discussion in 'Lounge' started by BoroRich, Oct 25, 2012.
  1. BoroRich
    BoroRich Elite Member
    Does anyone else run more than one monitor?
    What exactly does it do and how difficult is it to set up. I quite fancy running a second 23 incher but I think I might be getting into the realms of overkill :D
  2. arthurbikemad
    I run four in my workshop and two on another photo/video PC, it depends on your motherboard what slots it has and how the BIOS deals with them (for example some if running two cards will only output on one in 7 or both in Vista, thats Microsoft for you!) few mother boards have more than one AGP slot and so on (this is for more than one video card), if you buy a card that has dual/quad display its norm very simple, install card - load drivers and software - job done.. Well worth the effort imo and once you have dual display you will never look back!
  3. kpone
  4. arthurbikemad
    old image :D
  5. kpone
    Cheap, cheap, cheap.
    http://www.play.com/PC/PCs/4-/29681733/660966379/EVGA-NVIDIA-GT430-1024MB-DDR3-FAN-DVI-VGA-HDMI-PCI-E-Graphics-Card/ListingDetails.html?_$ja=tsid%3a11518%7ccat%3a29681733%7cprd%3a29681733
  6. kpone
    Wish I had a wider desk...
  7. Moily
    Moily Active Member
    Got space for at least 3 more monitors there, Ken! ;)
    These setups are pretty common where I work, although the most I've seen is 12:
    BoroRich: if you do get another monitor have a butcher's at this free util to give you a few niceties when stretching your desktop across both monitors
  8. arthurbikemad
    Got them on the wall in workshop :) no desk required...lol
    #8 arthurbikemad, Oct 25, 2012
  9. BoroRich
    I'm currently running one of these. I presume it'll handle dual monitors no problem.
  10. arthurbikemad
    You should see some of the CCTV video walls..
  11. Garyb
    Garyb Moderator.
    OMFG. Look at all them screens. I can't get one to run in the right resolution. "I have tried" sort of.
    But That my friends has tipped me over the edge.
  12. arthurbikemad
    Ok card, better with two in SLI mode :)
  13. kpone
    I do have a set up in my demo room running an Eizo 24" self calibrating monitor and a Cintiq HD 24 off the same PC. Does that get me back in the premiership?
  14. arthurbikemad
    Err I rekon..
    Ran out of room in workshop started sticking them any old where...lol Check out the old Sony....lol
  15. BoroRich
    I was going to do that but my motherboard's not got two of the correct slots :mad:
  16. Moily
    Moily Active Member
    Looks like it has 1 x D-SUB and 1 x DVI connector? If so, you may need an adapter if you have 2 x analogue or 2 x digital monitors.
  17. arthurbikemad
    Yeah you need a nice Asus mother board with two bad boy slots mate.. :) then she'll be rocking!! :eek:
  18. BoroRich
    Wouldn't it be cheaper to just buy a better GFX card? :D
  19. arthurbikemad
  20. BoroRich
    Oof!! :eek:
    Yeah I'll have one of those if someone's buying :D
