Leo Vince heat shield fitting issues
Discussion in 'Mods, Upgrades, Accessories and Products' started by Jollygiant, Nov 5, 2012.
  1. Jollygiant
    Jollygiant Member
    Did anyone else that has these had a problem with fitting them ?
    I've got all the brackets on but the shield touches the can, I've fiddled about with the can and the shield but it still touches.
    Did anyone take off the middle bracket of the exhaust link pipe to give a bit more play or anything else or am I just going to have to settle with the shield touching the can ?
  2. phantom
    phantom Active Member
  3. Jollygiant
    Jollygiant Member
  4. Jamiestrada
    Mine touched the Akro slightly, never marked it :)
  5. Jollygiant
    Jollygiant Member
    will have to have another look at it tuesday and see what i can do.
    Personally i dont think it should touch
  6. phantom
    Im not sure if its meant to touch but it seems to be common
  7. Nutty Tart
    Nutty Tart Well-Known Member
    Well mine never touched the Leo when it was fitted or the Akrapovic that replaced it .
    Perhaps you should loosen the exhaust clamps bolts ... give it a jiggle and re-tighten them .
    Just a thought
  8. phantom
    you should write fitting instructions, a breath of fresh air if it said
    check for clearance give it a jiggle and re-tighten lol
  9. BlackDevil
    Pictures installed head shield
    It might help...
  10. JM1
    JM1 Active Member
    Mine is v.close but not quite touching.
  11. lee711
    lee711 Active Member
  12. Jollygiant
    Jollygiant Member
    The leo can is different to the akra where it joins the link pipe, the akra has the taper but the leo is straight. That taper section on the akra seems to make the gap.
    I'll have a good wiggle of the can and link pipes and see
  13. BladeRR8
    BladeRR8 Active Member
    Can you not cut the carbon out to make a better fit and offer more clearance around the can ? I think I would rather do that than have the shield at a slight angle to the belly pan.
