Best battery charger
Discussion in 'Maintenance' started by burden8tr, Nov 6, 2012.
  1. burden8tr
    burden8tr New Member
    Hi guys just been in the garage to fire the blade up(2007) battery flat been stood a while now due to poor weather and work,removed battery to put un charge,problem was alarm kept going off so had to put battery back on.the charger I have is a big old bugger.wanting one of these new smart chargers,which one is the best to put on to battery whilst still on the bike and to be left on over winter.not worried about price too much just want best for bike,,as we all do.any advice would be greatly appreciated.
    Thanks
  2. JM1
    JM1 Active Member
    Optimate
  3. burden8tr
    Thanks for the reply feller but which one,1'2,3,4,5,6 there's that many,sorry for been so thick just not my thing.to complicate things further what can-bus fitting
    #3 burden8tr, Nov 6, 2012
  4. GappySmeg
    GappySmeg Well-Known Member
    I have Optimate 3+... works great.
    I also have an RR7, and they dont have a can-bus system... the optimate comes with a lead that you connect to your battery terminals then stash the other end somewhere convenient (I have mine under the pillion seat)... the Optimate connects to this lead when required.
  5. kpone
    If its not a Lithium battery the 4 is they way to go. Unless you want to use it for the car as well then look at the 5 and the 6. Gel batteries are a lot more particular and there are a few recommendations on here. Lots of different favourite makes championed but the majority swing towards Optimate. I love mine. Proper plug, play and forget.
  6. burden8tr
    So optimate 4 without can-bus.demon tweeks £49.99 delivered is that a good price.if so ill buy it now from the bay.?or any where better ,where you pro's recommend.want it fast
    Thanks
    #6 burden8tr, Nov 6, 2012
  7. kpone
    £50 is about right for it. Throw in delivery for that too and it's an okay deal.
  8. burden8tr
    Thanks to all that replied and thanks for all the help.know what to get now thanks again to all
  9. Remal
    I have a Optimate and Optimate 3 or 4 and both been great over the years at keeping my bike and kit car battery inn good nick. Only reason I would change is if I went to a Lithium battery
  10. burden8tr
    Lithium, one step at a time LOL.
    Thanks
  11. JM1
    JM1 Active Member
  12. Remal
    Was thinking about myself lol
  13. JM1
    JM1 Active Member
    I have a lithium but am too tight to buy a charger for it. It shouldn't drain much anyway.
  14. Fozza
    Fozza New Member
    I keep mine on an Optimate put it on whenever it's in the garage the battery will last for years.
  15. MrB
    MrB God Like
    I used to keep the bike connected to the optimate when not in use but now since the battery was fried I only connect it every now and again to test/top it up.
  16. wedgiewolves#223
    wedgiewolves#223 God Like
  17. kpone
    What happened with the battery Matt?
  18. JM1
    JM1 Active Member
    My 08 battery was fried too, but after about 3 years use and one winter left outside when garage was unavailable
  19. rocket
    rocket Active Member
    i run optimate too and fried my battery on blade before bike was a year old and had 1 fried on my 12r few years before. luckily mr b sorted it quickly for me ;) i now only put on about a week at a time in every month. so far so good.
  20. MrB
    MrB God Like
    Optimate was reporting a good strong battery but when tried to start the bike turned over very slowly but enough to start the bike. Didn't think too much of it, went for a run thought it would charge up a bit, got home tried to start and dead. Checked the charging all OK, connected up to the Optimate again it charged for a short while then clicked out to fully charged. Tried to start the bike and nothing. Did a drop test on the battery and it was no good.
    This was on my CBF500 with a 10 month old battery. I had heard of similar problems but dismissed them as my GSXR had been fine whilst connected over 5 years, obviously not all the time but for quite long periods during the winter months.
    I put the problem down to the Optimate so now as said connect it up every now and again to top up and test just to be on the safe side.
