RR7 and 1997 Bandit Paddock Stand
Discussion in 'General 1000RR Discussion' started by mara262, Nov 11, 2012.
  1. mara262
    mara262 Active Member
    Anyboby know of a good make of paddock stand that I could use on my RR7 and also a 1997 Bandit 1200.
    Thanks.
  2. martinowen
    Best off getting one with bobbin hooks if the bandits anything like the 6, I had one with the [ shaped bits that sit on bottom of swing arm and it didn't sit well on the bandit and was a pain to get on and off!
    Thinking about it pain on the blade too due to the swing arm being that odd shape one side
  3. mara262
    Thanks i'll check see if the bandit can take the cotton reel bobbins, or if I need to do a mod on thebandit swing arm to fit some. I suppse them it only comes down to the width of the paddock stand.
  4. martinowen
    I now use an abba stand on the blade and its really good, the other option is get an abba with adapters for both bikes
  5. largeviking
    largeviking Active Member
    Also have an Abba stand, easy to use and just get different adapters when you change your bike.
  6. JM1
    JM1 Active Member
    I use the cheapest one I could find with cups & hooks
