2017 CBR1000RR BATTERY DRAIN ISSUES
Discussion in 'General 1000RR Discussion' started by Nosh27, Apr 4, 2026.
  1. Nosh27
    Nosh27 New Member
    Hi guys .I think i have a parasitic drain.when I start my bike after one day the voltage is down to 11.9v..and when I checked it the day before it was 12.3v..I noticed a GPS connected underside of the fuel tank..just thinking if it could be that as I think the previous owner put it on..tell you the truth I dont know what it is but it does say GPS on it..I have already tried a brand new battery and it does the same..please can someone help..
  2. CharlieR85
    Trackers and alarms are the usual suspects, sounds like you've more than likely found it. Although beware its not a decoy, trackers arent meant to be that easy to find!
    If it were me I'd just remove it all together. Might be a bit of a hunt looking for how it's wired in though.
    Multimeter connected in line with the negative terminal and setup for Amps will display any parisitic draw.
  3. Nosh27
    Nosh27 New Member
    Thank you charlie..I might go hunting tomorrow
  4. Nosh27
    Nosh27 New Member
  5. Nosh27
    Nosh27 New Member
    This is what i found charlie
  6. CharlieR85
    Are you going to remove it?
  7. Nosh27
    Nosh27 New Member
    Iv removed it..im not sure what it is..last owner had it installed
  8. CharlieR85
    Pretty sure its a tracker mate.
  9. Nosh27
    Nosh27 New Member
    Yeah it's a scorpion tracker ..iv just taken it apart..it had a sim card attached aswell..defo tracker
  10. Nosh27
    Nosh27 New Member
  11. CharlieR85
    Honda dealers were giving away free trackers for a while.
  12. Nosh27
    Nosh27 New Member
    The lithium polymer battery in the tracker unit must of died and started sucking the battery from the bike.
