Clutch Covers 2004-2007?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Fergus, Apr 11, 2026.
  1. Fergus
    Fergus Active Member
    Hi all, I recently bought a new clutch cover that was advertised as being "2004-2007" but having problems fitting it.
    It's like the crank sensor is slight off position and hitting the gear/cog or the top shaft isn't lining up with the cover. Or there's some magic trick I don't know about.
    Anyway, are the clutch covers the same 2004 - 2007? My bike is a 2004.
  2. Fergus
    I got it fitted, pixies must have been at it all night.
  3. Muffking
    I thought the only difference between the one for the RR4/5 & RR6/7 was the colour, so I'm glad you managed to fit it ok.
  4. Fergus
    The only thing I did was remove the crank sensor and put it back on but, there's no play at all in those two bolts keeping it in place. Must have been the pixies.
