Dead clutch
Discussion in 'Maintenance' started by Ionized_Monster, May 14, 2026.
  1. Ionized_Monster
    Ionized_Monster Active Member
    My 04's been dry stored for about 8 months, I tried taking it out today but the clutch leaver is doing nothing, it has no resistance etc, I've googled it and it's saying that it's the clutch has locked up and needs releasing and re-oiling, has anyone else had this issue and do you have any suggestions on what to do?
  2. Selmer50mark
    Very much doubt the clutch has locked up , has the clutch reservoir got fluid in it, might just need bleeding
    #2 Selmer50mark, May 15, 2026
  3. Ionized_Monster
    It's got fluid and was only done last year, I'll bleed it and see what happens
  4. Ionized_Monster
    It's got a full reservoir and was bled and replaced last year but I'll give it another go and see if it helps, thank you
  5. Selmer50mark
    Seems strange the lever has no resistance
  6. bonjo
    push the bike around in neutral, then try to do it in 2 or 3rd gear, it may help
