throttle action
Discussion in 'Maintenance' started by bonjo, Jun 6, 2026 at 10:34 AM.
  1. bonjo
    I was wondering if I could reduce the effort to twist the throttle grip by opening it clean & lube as needed.
    Easy job, so I thought!:rolleyes:
    I just cannot undo the 2 screws on the handle bar cover! I do not want to take the hammer to it.
    Am I missing something?:confused: and any tips?
  2. CharlieR85
    Little ratchet set will give you more leverage than a screwdriver. They are bloody awkward.
    #2 CharlieR85, Jun 6, 2026 at 4:37 PM
  3. bonjo
    I'll try that. But shocked how tight is is unless it is reverse threaded:eek:
