Anyone know what this warning means on my car?
Discussion in 'Lounge' started by martinowen, Dec 17, 2012.
  1. martinowen
    Manuals are at home and I'm out in the car (Honda crv diesel) and this warning light has flashed up, any ideas?
  2. eyore
    eyore Member
    The oil can or the exclaimation mark ?
  3. BlackDevil
    Check your oil level !
  4. martinowen
    The can, other is handbrake
  5. eyore
    eyore Member
    Check your oil level QUICKLY !! and if its ok don't drive the car until you get it checked out.
  6. martinowen
    Oil level seems fine, it did the same symbol last week I turned engine off and on and it went away same happened today
  7. IcarusGreen
    IcarusGreen Elite Member
    It's the 'low oil pressure' warning light. Most common cause is low oil, other causes are oil pump has packed in, oil filters clogged/need changing.
  8. martinowen
    I will investigate further tomorrow
  9. martinowen
    Thanks everyone
  10. eyore
    eyore Member
    Just be aware Martin that driving it if there is a fault could do some damage to the engine,do for your own sake get it checked out. Better safe than sorry.
  11. martinowen
    Let the engine cool a bit on a flat and oil is sat just above the min by a mm so fingers crossed a top up will solve it :) just had to get 2 tyres costing me nearly a months wages so I hope it's just a top up lol
  12. Haggler ®™
    Haggler ®™ Active Member
    If it was a Merc (which it's not ) .........but just say it was........ then I would say that the oil level was low (hence the sqiggle under the oil can ),if the sqiggle was above the oil can then you would have been a numpty and added too much the last time you topped her up.
  13. kpone
    Oil can...?
    It's not a gravy boat then...
  14. eyore
    eyore Member
    Only sundays and christmas day :D
  15. martinowen
    That's the last f**king time I ask her to top up the oil!
  16. Beckers
    Beckers Elite Member
    Low Oil Deffo!
  17. martinowen
    Cheers Beckers, forgot you said you were involved with Honda cars when we were talking at the NEC, should of PM'd you first lol
  18. Beckers
    No worries dude. If its that low make sure you top it up and run it between the max/min marks on the dipstick.
  19. phantom
    phantom Active Member
    its a warning that shell has dumped more oil in the sea ;)
