Where to jack the front up when using ABBA stand?
Discussion in 'Maintenance' started by Muffking, Dec 18, 2012.
  1. Muffking
    To store the bike over winter i would like to lift it so that the weight is off the suspension by using my ABBA stand, but cant see where to get the front off the ground too. My old Ninja was fairly centre weighted so that a few blocks of wood under the engine would get the front off the ground, but the Blade is very front heavy from the centre pivots in the frame.
    Where should i lift the front?
  2. Hudson
    Hudson Active Member
    I have the exact same issue but i have a 954 blade, i am looking at getting a Harris front under yoke stand (Paddock Stands).
    I have the Abba front lift but to be honest it is utter rubbish and i would not trust a toy bike with it let along a Fireblade. I like the idea of a top yoke stand as it allows the front suspension to uncompress and of course lifts the front tyre off the ground.
  3. Jollygiant
    Jollygiant Member
  4. Muffking
    Ahh good one. I'd forgotten about this after i saw it at the NEC show last month. It pulls the back down, which lifts the front up.
    I could probably just ratchet strap the swingarm/wheel down on my ground anchor.
  5. arthurbikemad
    I know what im making tomorow.....lol Not seen that before...im slacking!
  6. martinowen
    Not seen that before either, would that not affect your rear shock though?
  7. arthurbikemad
    You could hook it up to the sub frame/rear pegs if you don't want your shock topped out.. ;)
  8. Jollygiant
    Jollygiant Member
    well ive just ordered the package that comes with the stand and this front lift, soon see if its any good.
  9. martinowen
    Sounds good, you gonna try make one then?
  10. 1000rr73
    1000rr73 Active Member
    I'm hoping mrs Christmas brings me this next week.
  11. arthurbikemad
    Try....lol No I AM going to make one, and paint it red....lol
  12. martinowen
    Lol sorry that's what I ment
  13. arthurbikemad
    Best not say too much, patent police will come and kill me....lol
  14. martinowen
    Let me know how you get on ;)
  15. Muffking
    Yeah pics would be good. You could make a killing if it works ok as ABBA want £50 for theirs and i can arrange a courier to pickup for a fiver :)
  16. Remal
    Just a warning on using the ABBA stand and a headstock stand, which I had until last year. when using the ABBA stand it does not lift the bike up enough and once you use a headstock stand it brings the front up but lowers the back wheel just enough onto the ground to stop you moving the rear wheel.
    So I went for a Harris rear stand and got ride of the ABBA. nice as it was the Harris stand is easier to use in my garage as it's close to the wall on the right hand side
  17. Hudson
    That is interesting as this is exactly what i was going to do.... which Harris rear stand did you get ? Just the plain paddock stand ?
  18. Remal
    I went for the HARRIS STAINLESS STEEL "PRONG TYPE" REAR PADDOCK STAND second one down Paddock Stands
    I use a Biketech headstock stand on the front. and as the ABBA raises the bike mid way it was not far enough up to lift the rear wheel
    And have this from stand. both work very well togeather. Front Headstock Stand | Any bike
    But if I did not have it then I would go for the Harris head-stock stand in a second. the quality if first rate
  19. Hudson
    Bugger..... I really wanted the Harris Headstock stand but really like my Abba stand.....is nothing easy !!!
  20. Jollygiant
    Jollygiant Member
    I've got a head stock stand that works fine with my abba stand. Rear stays off the floor and front up aswell.
    Can't remember the make will have a look tomorrow for you if you like.
