height adjustment ?
Discussion in 'Maintenance' started by steve b, Jan 30, 2013.
  1. steve b
    steve b Active Member
    As i am not to tall the blade is right on the limit of my comfort zone with regard to puting down the old feet when stopped junctions etc
    Is there any easy not to intrusive way of lowering the bike ,its a 2012 abs model
    cheers
  2. thefirebloke
    thefirebloke Elite Member
    These might be able to help your situation!
  3. steve b
    thanks mate have sent them a mail so lets see what they come up with
  4. steve b
    mmmm mr glitter used to make me polish his
  5. Shine on
    Shine on New Member
    Booking o8 blade in for MOT and Hypopro lowering spring have trailed through all the chaff and spoke to suspension people and this is the compromise to price and setup. hope to have it back in a week or so. Will keep you posted
  6. Givover
    i have seen a blade with this lowering mod .Just a note see if you can look at a bike with it done, as it really spoils the back end and looks pants!
  7. BoroRich
    BoroRich Elite Member
    How tall are you, Steve? I'm not exactly a Harlem Globetrotter myself and I never feel uncomfortable.
  8. eyore
    eyore Member
    I dont believe is possible to lower a bike without compromising the handling, ground clearance and also the side stand wont work. Not a good plan...............wear high heels:D
  9. Slick
    I'm 5'3 and 70kg, adjusted the preload front and rear to get a around 38mm sag, this helped lower the blade from tippy toes to a more comfy balls of feet.
    If you're pretty light you might want to try before altering geometries etc
  10. Shine on
    Shine on New Member
    Too late spring ordered going in Saturday. Will watch and see and try the differance if PANTS then its ( the spring ) will be going on ebay
  11. steve b
    all done yet and if so any thing to report??
  12. Shine on
    Shine on New Member
    Height adjustment to RR8 blade
    Still waiting for spring to arrive its a Hypro progressive spring from Holland, takes about two weeks. I had it posted to local garage. As soon as it arrives i will do a before and after with photos
