Hi guys intfoduced to the site from krl, wander if you guys can help please, bike wont start but is turning over,fitted new battery, indicators not working and hazard lights not working, checked fuses, kill switch all wiring seems to be fine,blade 2008
Yes and have tried it up also, but in neutral should srart anyway,when you turn the key there is no sound of things connecting from the the ignition barrel
Hi mate and welcome to the forum.dont worry about the prob with the bike If the guys on here cant tell you how to fix it then it must b totally dead
Welcome Ciaran, disconnect battery again and use the spare key to start.The hiss may not have recognised the key you are using.Hope this helps.
