Chain Adjuster Options
Discussion in 'Mods, Upgrades, Accessories and Products' started by exfire, Feb 7, 2013.
  1. exfire
    exfire Elite Member
    Hi All,
    Looking around for new chain adjusters for my 2006 model. I have read some threads about Lightec and Gilles but are there any other manufacturers I should consider ?
    Any helpful advice or feedback on Lightec and Gilles would also be helpful.
    Thanks Nigel
  2. Jamiestrada
    No Gilles are excellent as are lightech pick either you can't go wrong :)
    I prefer Gilles :)
  3. exfire
    exfire Elite Member
    Thanks Jamie, both look good.
  4. Si.
    Watch the bolts on the lightech, they are crap… i changed mine for stainless jobbies as the originals are soft as philadelphia.
  5. BlackDevil
  6. Andrew
    Andrew Active Member
    I've got the Gilles ones, but I seriously like the Titax ones!
  7. exfire
    exfire Elite Member
    Thanks .The Titax look nice but not sure if they do one for an 06.
  8. vale
    vale Active Member
    i made my own
  9. exfire
    exfire Elite Member
    Very nice Vale.
  10. ColinBR
    Gilles are proper precision engineering.
    I can appreciate the work gone into them when I see them.
  11. Givover
  12. BlackDevil
  13. exfire
    exfire Elite Member
    Thanks BlackDevil that was useful.
  14. Chillipepper83
    Chillipepper83 Active Member
    Lightech = good quality and super easy adjustment!
  15. Slick
    I was wondering, what is the better investment a chain adjuster or a laser alignment tool?
  16. billo01
    billo01 Member
    Out of the Gilles, which works best and is easiest to use TCA or KTS or are they basically the same?
  17. Jamiestrada
    TCA are excellent you adjust with Allen key then lock off and forget, also make it easier to fit the back wheel :)
  18. ee8
    ee8 Member
    Lightech here no complains. Works like it is supposed to.
    Nothing wrong with the bolts... maybe they upgraded.
  19. MrB
    MrB God Like
    They are different bolts to my lightech adjusters.
  20. gringo
    gringo Active Member
    I have gilles adjusters and uplifters on my 06 blade
