Sod it, I've had enough
Discussion in 'General 1000RR Discussion' started by Remal, Feb 17, 2013.
  1. Remal
    I really have. first foray in the taking bikes apart, have enjoyed it But now the the fcuking bike won't start.
    After Christmas the fuse went, bike would start but no lights etc... the bike started up straight away after months of being in the garage
    So took the bike out yesterday to finish off the track fairing. Would not start. sod it, maybe the Lithium battery. So put the original back in. Nothing again just cracking over but not starting
    So thought I would leave the bike with the original battery on the optimate until after work today.
    Bike battery fully charged. Still just cracking over. Kill switch checked twice. fuses checked 3 times. fuel in the bike, only thing I have done is to fit the faring. I have no touched the wiring etc...
    sounds like starting the bike with the kill switch off
    FFS well annoyed. any tips.
    I get the lights on turning the key, clicking from the under seat, unsure if I am missing a fuel pump noise. Does it normally do that? I can't remember
    #1 Remal, Feb 17, 2013
  2. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    On my 2010 you always hear the fuel pump when turning the ignition
  3. Slick
    I'd check your kill switch again. Mine stuck the other week due, not sure why.
    With the ignition on flick it off and on again, the pump should prime and other bits and pieces do some diagnostic stuff so you should hear a load of clicks and noises. If not spraying some WD into the switch may help unstick it.
    Hopefully its something simple.
  4. Muffking
    Yes you should hear the fuel pump prime the engine when the ignition comes on (assuming the immobiliser is off). Is the tilt sensor still sitting vertical in the new fairing?
  5. Remal
    what a total cock
    tilt switch you say. Must remember to fit that back on
    twat award no 2
    Call me mod twat
  6. phantomx0_1
    phantomx0_1 Active Member
    I second what everyone else says. Is the tilt sensor sitting right and yes you should hear the pump?
  7. Muffking
    Notice the lack of sarcasm in my post.
    You can repay me by buying me a pint on the Scotland trip, unless you're not going, in which case you can have that one for free :-D
  8. Remal
    Muff I owe you one and no I'm not going but we need to meet now. Stella
  9. Muffking
    Lol. Have you refitted it to confirm that was definitely the problem and that there's nothing else?
  10. Remal
    I got the wife, got her to hold the tilt sensor and the bike started straight away. left her to told ddaid tilt sensor for a few mins while the bike warmed up
    In other words as soon as I read "tilt Sensor2 I THOUGHT, BALLS. and the bike started
  11. martinowen
    I think you are a strong candidate mate lol
  12. Dano28
    Dano28 Active Member
    haha been there done that, thats how I found out what the tilt sensor looked like when I found the big arrow on it saying this way up facing the ground!! horrible when that panic sets in thinking ive f**ked it :eek:
  13. Remal
    I feel the force is strong in me
  14. kpone
    Force as in accelerometer...
    As in now correctly aligned.....?
  15. Remal
    Not after the beers I've had tonight and G&T
  16. Hudson
    Hudson Active Member
    What the hell is a tilt sensor ? I own a 954 so am unfamiliar in such things.
  17. phantom
    phantom Active Member
    how many people get owned by tilt sensors these days lol
  18. Muffking
    It's good to know that your engine will cut out in a spill though. Could save more damage to the bike and even the engine if the casings are damaged.
    That should answer your question too Hudson.
