Short levers, I'm not sure?
Discussion in 'General 1000RR Discussion' started by Carl, Feb 17, 2013.
  1. Carl
    Carl Well-Known Member
    I have just fitted Pazzo shorties and I'm not sure I like the clutch lever, I have Alpinestar gloves with the little and ring finger locked together, this make the short lever a little uncomfortable because when in trafic and using four fingers the little finger hangs over the edge of the lever and feels trapped. Has anyone else had this problem and will I get accustomed to the awkward feel?:confused:
  2. phantomx0_1
    phantomx0_1 Active Member
    Some run a long clutch and short brake for the traffic reason. I used to do it but now I don't really commute much on my bike. Your problem with the gloves sounds like it would wind me right up!
  3. raphael
    i have asv short levers on mine mate and have the same problem as you, as good as the levers are it took me awhile to get used to them, i use the lever nearer the end now so two fingers hang on the end of the lever which is much better/easier in traffic
  4. Jollygiant
    Jollygiant Member
    I had short levers and promptly got shot of them for long ones for those reasons.
    I just prefer long ones.
  5. Stimo
    Stimo Member
    i have pazzo shorts , the clutch i never had problem with mine was more the brakes getting used to but im fine now
  6. jamesm09
    jamesm09 Senior Member
    I have trouble with the short clutch lever. I'm going to fit the original clutch lever back on. I do like the short brake lever though.
  7. SimonRR
    SimonRR God Like
    I went for Harris folding levers in the end Carl, the clutch is just a little shorter than std and the brake is around 3/4 std length, they have loads of adjustment and feel real good :)
  8. hump333
    hump333 Member
    My Pazz short levers are good stuff, Ive bleed them up and got them on setting 3 on break & setting 4 on clutch. My clutch is hydrolic type tho and flush every 6000 miles :)
  9. AshBlade
    AshBlade Riding Goddess
    Long Pazzo levers,first try with them on today and there terrific... i'm very happy with them.:D
  10. Freedom of choice
    Carl, what did I say to you at the end of last season…….
    I fitted ASV short levers, I liked the brake straight away but the clutch is another matter but having only ‘gone round the block’ I was not sure it’s just a case of getting used to it. Interestingly I also have Alpinestar gloves and the same concerns as you. If I can’t get on with it I will either put both OE levers back on or buy a longer ASV clutch lever.
  11. martinowen
    You may get on better with harris ones they are inbetween the 2 sizes
  12. Carl
    I know jolly I bought them off of you;)
  13. martinowen
    Pmsl ^^^
  14. Freedom of choice
  15. phantom
    phantom Active Member
    I like shorties as I am used to using one finger braking and
    two finger clutch use.
  16. Clarkey
    Clarkey Member
    Lads I love short levers have had them
    On all of my bikes just waiting for a secondhand
    Pair to come up on evil bay or our fourm
    So if Any of you out there wants to sell
    Get in touch please
  17. martinowen
    Looks like Carl's might be up for sale soon, get your name in there quick ;)
  18. BlackDevil
    I got the long ASV levers instead of the short once because of the same problems.............
  19. sinewave
    Bought the long Pazzos myself just feel and look better, whether they snap off or not if the bike gets dropped would be the least of my worries.
  20. BoroRich
    BoroRich Elite Member
    I've got Pazzos and I run a shorty brake lever and a full-sized clutch. I thought this was a better set up for the road.
