Snow day tomorrow ??
Discussion in 'Lounge' started by Jollygiant, Mar 11, 2013.
  1. Jollygiant
    Jollygiant Member
    So any one else thinking it might be a snow day for them tomorrow ?
    Snows coming down well here in Sussex and is set to till 7 am apparently, so with that and the fact not one single gritter has been out I think it may be a snow day tomorrow.
    Oh and the fact I parked my work van down the bottom of a hill :D
  2. kpone
    I don't think it'll be a snow day for me but it may well be a front wheel drive day.
  3. Barney1
    Barney1 Guest
    Snow , -8 , windy , outside taps frozen , horses water frozen ,
    Fire won't go properly , happy days :(
  4. kpone
    Not the new one Steve?
  5. Barney1
    Barney1 Guest
    Do you mean log burner ? If so yes its pissing me off big time :(
  6. kpone
    Bugger, not good this week. Is it not drawing?
  7. Barney1
    Barney1 Guest
    Blowing fumes back into house ,
    House stinks of smoke ,
    Don't know what hell is wrong with it
  8. Jollygiant
    Jollygiant Member
    Does it use a chimney or a metal flue mate ?
  9. Barney1
    Barney1 Guest
    Chimney mate , its all been cleaned out two weeks ago ,
    But was working fine last night ?
  10. Jollygiant
    Jollygiant Member
    Might just be because its so cold outside and its not getting warm enough to start drawing.
    If you have a blow torch or something use that to heat the chimney up.
    Just stick it up the chimney for a bit on full whack.
    Would also help in future if you had a flue liner dropped down the chimney aswell, will also be safer.
  11. ColinBR
    Sounds like a lovely summer evening up here mate. Stop fookin about n get to fooking work ya lazy arse ;)
  12. Jollygiant
    Jollygiant Member
    Snow day for me as predicted.
    This is the back garden.
  13. kpone
    Brilliant sunshine here. Yesterday's cold and wind burned off most of the moisture in the air so no frost, only exposed water has made any ice so all in all an excellent day as long as any exposed flesh isn't facing the wind.
