Spraying rear sets
Discussion in 'General 1000RR Discussion' started by Yorkshire Tyke, Mar 10, 2013.
  1. Si.
    This is when I had them back, and assembled them:
    Cover that was powder coated:
    close up of rizoma pegs:
  2. phantom
    phantom Active Member
    cheers for that.I'm thinking of getting mine done gold to match the wheels.
  3. ray
    ray Well-Known Member
    Looking at this pic of my original rearsets, does anyone know if any metal can be removed without compromising the strength of them?
    Was thinking of the two triangular areas and the piece that stands tall/proud of the rearsets (held the original heat shield in place)?
  4. Shing90
    Shing90 Active Member
    Why would you want to do that Ray? If you don't mind me asking..
  5. ray
    Just thinking about making them look a bit better as I'm toying with idea of having them powder coated :)
    Thought if I'm gonna go to the trouble of powder coating then the least I could do is get rid of the ugly hanger. Then I thought, well if I'm doing that I may as well see if there is a way of cutting out the triangles without compromising the strength of them. Also, it would get rid of the ugly hole in the bottom triangle :)
  6. ray
    When I say the triangular pieces, I do mean the recessed parts of the footrest & not just cut off the whole top half of the rearsets (if that makes sense) :)
  7. Shing90
    I see what you mean.. I would say that is entirely possible. Plasma cut, tidy up, and then powder coat gloss black.
  8. martinowen
    What year is the bike mate ?
  9. martinowen
    Drill some holes in a triangle shape if that makes sense, that way you won't loose as much strength and will look better and be lighter
  10. ray
    2007
  11. Andrew
    Andrew Active Member
    If I was doing that I don't think i'd remove all of the metal out of both triangles to be honest.
    I think i'd go a mm or two in from the edges roughly were the radius from the hole finishes!
    I think it would make them stand out from the normal and if your patient and carefull should be do-able with a file and dremmel!
    #31 Andrew, Mar 13, 2013
  12. Toy40
    Toy40 Active Member
    rr5
