Oil Use...
Discussion in 'General 1000RR Discussion' started by travellingkiwi, Mar 15, 2013.
  1. travellingkiwi
    travellingkiwi Active Member
    How much oil does your blade use? When I picked up my bike today, the dealer told me to keep an eye on the oil level as blades can use up to 1 litre of oil between services... WTF? Or are Honda using oil injection in the cylinders?
    H
  2. Remal
    Have a search many big threads on here should help answer your question :)
  3. Alblade
    Alblade God Like
    Welcome to blade ownership -
    3.5 litres in a week was my worst experience , to be fair over 3,000 miles
    Its better now - but def. check it every 500 miles
  4. sinewave
    What is the favoured Oil for Blades owners?
  5. Alblade
    Alblade God Like
    I use Hein Gerrick stuff - paid £10 for 4 litres - got given about 15 1 litre bottles of various brands as a wind up birthday present one year - I can rate the bottles more than the contents - most of it has been used now and mixing it all up made no difference (in last 20,000 miles that is)
  6. abv
    abv Active Member
    08+ Castrol Power 1 Racing 10W/30
  7. phantom
    phantom Active Member
    have 800 miles on mine so far .............. no oil used sbiting_nail-biting_100-102.gif
    do you think something is wrong, maybe see what the dealer says?
  8. Alblade
    Alblade God Like
    I have one of the few UK blades which got rebuilt under warranty due to oil use - some of the first batch of bikes affected - it became a joke and used 1 litre in 472 miles or something on the formal oil use test - Honda then said 'oh you started test in Manchester dealer and finished it in Oban Honda dealer so not valid, you will have to re-do it' was a small question of had it used 980ml or 1000ml of oil (like one figure was acceptable and the other unaccaptable)
    God I'm ranting but had to go through so much pain to start with!
  9. phantom
    I remember you going through all that, think milf hunter an badger had the same problem
    as well as the cam pulse failures
  10. slasherr
    slasherr Active Member
    For the 1st 10000 miles mine consumed about 450ml / 1000 miles, I was totally disgusted with this figure but was advised by several Honda dealerships who had all been practicing their straight face that upto 1000ml / 1000 miles was totally acceptable for a new bike that cost £10,000.
    Its approaching 20000 miles now and has slowed to under 250ml / 1000 miles, who knows by the time its reached 50000 miles it may not use a drop.
  11. Ian E
    Ian E Active Member
    Never really measured mine (08 model), but oil consumption is minimal, I'd say less than 200ml per 1000 miles, certainly no worse than the RR6 I had before.
  12. BlackDevil
    The oil consumption is minimal almost nothing ( 2011 Blade ).
  13. sinewave
    You used to get high oil consumption from being too gentle with the running in process. :eek:
    Thrape em from new I say! :D
