applying stickers
Discussion in 'Mods, Upgrades, Accessories and Products' started by steve b, Mar 23, 2013.
  1. steve b
    steve b Active Member
    Have got to apply my epsol sticker to screen on instuctions it says to apply detergent 1st,i have been told that you can do it using a week soapy water mix which helps to place move and apply the sticker any tips anyone ?
  2. martinowen
    Windolene does the job on most sticker fitting jobs
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    Yeah or a bit of fairy liquid with water you can move them about and will dry out and give you chance to pull off if needed and re apply
  4. dessp2
    dessp2 Well-Known Member
    Use baby shampoo as it doesnt contain salt.
  5. derick
    derick Active Member
    The venture shield kit has a smal (200ml) bottle with a few drops of baby wash (blue bottle Johnson and Johnson stuff which you then fill up with water. It holds enough to do the whole set for the bike.
  6. travellingkiwi
    travellingkiwi Active Member
    Dishwashing liquid usually contains salt... Car shampoo would be better (Not supposed to contain salt).
    H
  7. wedgiewolves#223
    Never had a prob with all I've stickered up each to there own i suppose ATTACH]9431[/ATTACH] ImageUploadedByTapatalk1364129432.579809.jpg ImageUploadedByTapatalk1364129461.064907.jpg
