What tools are needed for DIY chain and sprockets change?
Discussion in 'Mods, Upgrades, Accessories and Products' started by drewl999, Apr 17, 2013.
  1. drewl999
    drewl999 Active Member
    Hi people,
    I'm ordering tsubaki sigma x ring gold chain and renthal sprockets -1 front, +1 rear. I've been looking through the forums and watching youtube vids, but I want to know all the tools/kit I'll need. Any info will be much appreciated.
    Drew
  2. lee711
    lee711 Active Member
    chain breaker / riveter tool, socket set, and a piece of 2x3 to wedge through the back wheel.
  3. drewl999
    Cheers, any recommendations of breaker riveters? I'm guessing the cheaper ones will not be adequate?
  4. Slick
    Just done this myself, before you buy all the tools consider your local dealer will fit for £60.
    See my thread for the essential tools. http://1000rr.co.uk/mods-upgrades-accessories-products/9995.htm
    Having just done this, and if you still want to DIY, do yourself a favour and get a DID chain instead, Tsubakis come with a solid rivet link which to be riveted properly needs a pricey tool. DID chains are hollow rivets that can be done with a cheapish (30 quid tool).
  5. drewl999
    Yeah, it'd be easier to just get it done professionally, but I've got a bit of time on my hands and I'm enjoying doing bits and pieces myself at the moment. Hmmm, I'll look at did chains, I know many on here recommend them
  6. Slick
  7. ColinBR
  8. Slick
    wish I saw this a few weeks ago!
  9. ColinBR
    Typical ain't it ;)
  10. drewl999
    Colin, with me being a bit new at this, would that breaker riveter work on tsubaki chains?
  11. ColinBR
    Well I'm going to buy 1 if that's anything to go by mate.
    I understand your doubts as it says for Regina chains only and not for DID. Reason for not for DID is that they use soft links, reason for Regina only is for sales reasons ;)
  12. Muffking
    Nahh forget all that
    Get a cutting wheel on an angle grinder to cut the chain off and then grind the head of a G-clamp into a pin shape to open out the rivets on the new link. Worked on my ZX6R :-D
  13. ColinBR
    Was that maybe with a soft link though mate?
  14. Slick
    I used the cheapo DID type tool to remove the old chain and press the plates on the new one. As I did not have a proper tool to rivet the Tsubaki just used a Sledge hammer as a back stop behind the chain and a small club hammer to peen the rivets. Just take your time and aim well!
  15. Muffking
    Good point, yes it was.
  16. Evogixer
    Evogixer Active Member
    I also use digi verniers on the link, so you match the factory link width. All too easy to press the plate on too far & crush the o rings.
    #16 Evogixer, Apr 18, 2013
