Back Protectors
Discussion in 'Mods, Upgrades, Accessories and Products' started by exfire, Apr 29, 2013.
  1. exfire
    exfire Elite Member
    Hi all,
    I am on the look out for a good quality back protector, the type you wear under any type of jacket. I have always relied on the insertable ones that fit inside a pocket in the jacket. As I am getting older, safety is finally starting to be a bigger thing in my mind than it used to be and I would like to be able to have good protection whatever jacket I am using.
    So can anyone please offer me some advice based on experience, of a suitable back protector, there are so many available and I would appreciate your help. I would like something that is not too bulky, does not restrict movement too much and is not too hot Oh yes.........and provides good protection :D
  2. And7rp2
    And7rp2 Elite Member
    Me too ?
  3. sinewave
    Me too! :confused:
  4. MrB
    MrB God Like
    just got one of these
  5. MrB
    MrB God Like
    got one of these for sale it has been used but in good order
  6. MrB
    MrB God Like
    can also supply new if your interested.
  7. fez.57
    fez.57 Well-Known Member
    I had a good luck at these at the n.e.c this year, about £95 i think very thin and the quality looked spot on
  8. rewy..rr
    rewy..rr Active Member
    For the last 7/8 years I have worn a Knox Ricochet 8 plate, back protector, and had no problems
    Snug fit, under my Wolf 1 piece leathers, and at first a bit of a struggle to get on, but once you get the hang of it, its simple enough to put on.
    Advantages, its not to heavy, does not restrict movement, provides additional warmth it winter, and its not too hot in the summer.
    Wouldn't ride bike, now without it.
  9. Si.
  10. sinewave
    Do they not make ya back sweat?
  11. 1000rr73
    1000rr73 Active Member
    What about the alpinestars trackvest. I'm selling mine in the classifieds here.
  12. Si.
    nope... Not atall. Plus, if it did, it's better than a bust spine.
  13. sinewave
    Might av to invest in one when I purchase some leathers.
    My Textiles have all that built in so I'm OK for now
  14. Muffking
    I've been using a similar one to the Forcefield Level 2 posted earlier.
    It's the flagship Forcefield Pro Sub 4, cost around £150.
    http://cdn2.bigcommerce.com/server2.../PRO_SUB_4_01__86561.1308512652.1280.1280.jpg
    Back protectors tend to be rated by saftey level 1 or 2. Level 1 can disipate 1kg of force & Level 2 disipates 2kg of force. There is no level 3 onwards standard, but Forcefield introduced the slightly thicker Pro Sub 4 which disipates twice as much force as the Level 2 back protector, which is why i bought one.
    There's also an optional chest protector which i bought for around £20-40.
    There's only one other back/chest protector that i would consider using, which is this one that fits like a gillet and has extra padding for the collar bone.
    http://img.inkfrog.com/click_enlarge1.php?image=Track_Vest_BLACK_WHITE.jpg&username=augusta154&aid=665931946
    #14 Muffking, Apr 29, 2013
  15. sinewave
  16. lee711
    lee711 Active Member
    Me and the mrs have been wearing these for the past couple of years, very comfy once on and warmed up, not too restrictive and after a while you don't even realise its on, also has easy attachment of the matching chest protector. You need to measure your torso to ensure the correct No. of plates. To be honest the support is comforting and you feel a bit vulnerable without it on.
  17. Muffking
    In fairness i bought mine from a local dealer as i wanted sizing up so probably paid full price, but after lots of research it was the one that offered the most protection and covers a wider area of the back than most and has integrated kidney protection.
  18. SimonRR
    SimonRR God Like
  19. RedMacGregor
    RedMacGregor Active Member
    I use a Knox back protector - they don't seem to sell my model any longer but it's light and doesn't make your back sweat (not that is likely this year so far). I have read the Forcefield back protectors are very highly recommended. One thing to consider is if your leathers are tight the back protector does take up some space making a snug set of leathers a bit tight. During the cold weather with the extra layers I've struggled to do the zip up on my jacket. So worth trying the back protector at the shop.
  20. Gblade
    Gblade Active Member
    Same as Lee, Knox is comfy and doesn't get too warm in the summer there's space for air to flow. Once you have used one you'll never ride without it.
