I have a PAIR of motors for sale which were going in a race car, I've now seen a complete car i wish to buy so need the cash. Willing to sell individually but WILL NOT BREAK. One is complete apart from ECU, one needs clutch pushrod, sprocket cover and slave cyl and coils plus again no ECU. Both have looms and TBs. I was assured that they were very low milage as they came from damaged bikes, i cannot verify this. Looking for £1400 each or VERY nearest offer. Text me anytime, 0seven845 82seven98seven, Dean.
give mike@ racesparesuk a pm,i know he's after a motor. also i have all the bits your missing (not ecu+loom) if you want to make both complete.
Cheers for that fella, just shot him a message thru his website... What have you got for me then? Don't really wanna spend any more on them but if the bits are cheap...
pushrod,clutch slave,sprocket cover+coils.(broke 3 engines over the last few yrs ) you can have them all for £60 delivered
yea i think i've still got it all,will check the coil loom,i do have a loom part but not 100% sure what it's from without looking.
still got it all,and have a sub loom for either the top injectors or coils,not 100% sure tbh,but you can have it either way.
Actually just remembered some moar stuff i need, i'm missing four clips for the rubbers where the throttle bodies mount and i also need a pair of gear levers, not the foot lever but the piece that fits onto the splined selector shaft...
you mean the knuckle on the gear spline? i have 1 but it's not standard,it's a machined ally 1,and think i have the throttle body clips but will need to check.(i assume you mean jubillee style clips with a locater hole on them?) got a spare tuned head so the might be on that.
Yes mate, those are what i'm after, don't worry about the gear selector for now then, i'll sort some from somewhere. ;-)
