New member.
Discussion in 'New Members' started by foss, May 2, 2013.
  1. foss
    foss New Member
    Hi all just signed up so i give an intro. Iv got a 61 plate repsol blade had it 4 month and been doing bit to it. Started putting pc5 yoshi r77 slip on with no baffle and k&n filter having a bit bother locating the 02 eliminator plug . Any help would be great.
  2. BoroRich
    BoroRich Elite Member
    Welcome to the forum, fella. I'm sure you'll enjoy the place. Great bunch of characters on here.
  3. martinowen
    Hi and welcome
    Someone will be along with the answer soon
  4. foss
    foss New Member
  5. Remal
    Welcome to the forum, I have a 60 plate repsol, with a R77 exhaust and K&N filter but not much help as this was fitted by JHS racing in Bristol at the first service. I also had the Bazzaz fitted and it all dyno'ed. So hoping someone will be along soon to help you out some more than I have
    Again welcome
  6. lambeth longshanks
    Welcome aboard, shipmate.
  7. Si.
    follow the wire from the original exhaust, the connector is right behind the left side fairing. You can get to it without taking the side fairing completely off.
  8. Doodles
    Doodles Active Member
    Hello and welcome
  9. foss
    foss New Member
    Thanks for the replys and help. I managed to get to the plug, I tried from the left side but with it being an ABS model I couldnt get to it as it was clipped to the harness. So I WENT IN FROM UNDER THE TANK . I took the tank off and it was easy I just located it by chasing the cable from the bottom after taking off the plastic engine cover to enable me to see the cable. Then I found the correct 1 as there is 2 very similar. IT SOUNDS LIKE A BIG JOB , BUT i JUST TOOK MY TIME AND HAD IT DONE WITHIN AN HOUR. Anyway iv taken it out for a test and believe me its great smooth thru the gears right thru to high rpm . Its has realy improved the low down power it hasnt got that delay anymore. Forgot to mention my bike had a akrapovic slip on with tie same power commander SET UP and it wasnt as quick down below mayby this was Due to not having the eliminator on at the time . But im pleased with the set up so im leaving it alone.
  10. foss
    foss New Member
    The Akra is for sale if anyones interested. Its mint no dents or marks, comes with all the parts.
  11. derick
    derick Active Member
    Welcome to the forum mate.
  12. steve b
    steve b Active Member
    hi mate welcome to yhe forum
  13. shawn57
    shawn57 Active Member
  14. phantom
    phantom Active Member
    Welcome aboard
  15. foss
    foss New Member
    Thanks Guys.
  16. BlackDevil
    Hi and welcome Foss!
