Feck It, just blown a seal
Discussion in 'General 1000RR Discussion' started by Slick, May 19, 2013.
  1. Slick
    While polishing my Blade noticed oil on my front wheel. Noticed oil leaking from one my fork seals :mad:
    Hopefully my warranty covers this(fingers crossed!)
  2. kpone
    Beats clubbing one.
  3. Slick
    Ja, blowing one has left a bad taste in my mouth, kinda fishy.....
  4. thezipsteruk
    thezipsteruk Elite Member
    have you been out riding with dougie lampkin again?
  5. sinewave
    Honda aren't known for being sympathetic to replacing Fork seals under warranty.
    They tend to infer you've been a bit of a 'Wheelie King' and thus decline to repair FOC.
  6. Slick
    Jeez, I hope not, paid good money for extended warranty, that said got my money back already with ABS bleeds, calliper server and headstock bearings all covered.
    Anyone know if it is safe to ride with a slight leak?
  7. JM1
    JM1 Active Member
    IME, you'll be fine riding normally with a slight leak for a while, but just be aware of it, don't ride like a loony, and watch for fluid getting on to the tyre.
  8. Barstewardsquad
    I recently had my fork seals replaced and needed to do the brake pads at the same time due to contamination so check you pads carefully.
  9. Slick
    Thanks for the heads up, luckily I both a job lot of EBCs so have enough for a few seasons
  10. Slow and fast
    Slow and fast New Member
    Change the seals yourself, its not a big job to do it.
  11. Slick
    I would do normally but hopefully this is under warranty
  12. ColinBR
    Very much doubt it'll get done under warranty mate. It is a wearable item. Comes under the same thing as tyres and brake pads.
  13. Slick
    Right you are, I did clean them post replacement of the seals and they looked OK and felt ok. Hadn't really used the brakes in anger until doing 160+ on a track day at Bedford Autodrome.:eek:
    Watch at 1:58 where pass on the straight I try to brake hard and get nothing but smoking foil oil! Could have ended bad but it didn't:)
    Honda Fryblade - Smokey Brakon - YouTube
    Let this be a lesson!
  14. lambeth longshanks
    Just seen this thread and hoped that the OP had been tampering with aquatic mammals perhaps while under the influence.
    Oh well.
    #14 lambeth longshanks, Jun 12, 2013
  15. kpone
  16. Barstewardsquad
    Yikes!!!
  17. Slick
    Saying that my brakes are now awesome since I've cooked the oil off!
  18. sinewave
    There was a lot of daylight under them knees in that Vid! ;)
  19. wedgiewolves#223
    wedgiewolves#223 God Like
    Nice seeing you there yesterday mate you was going well
  20. Slick
    Don't make me cry ,was trying my best. One day..... maybe I need thicker sliders
