datatool gear indicator trouble help
Discussion in 'Mods, Upgrades, Accessories and Products' started by rr4tom, May 25, 2013.
  1. rr4tom
    rr4tom New Member
    hi guys, i fitted a datatool gear inicator a few months ago, i have this wierd problem thats just started a couple of weeks ago, my fuel light sometimes comes on when i change gear, not alll the time. I think it may be related to the gear indicator i fitted. I can't find any diagram to double check the right colour wires. Does anyone have a 2004 honda fireblade wiring diagram showing which wires are what colour. thanks
  2. Barstewardsquad
    Which wires do you want to know, I'll have a look in the Haynes manual for you.
  3. rr4tom
    rr4tom New Member
    Earth, Ig live, Rpm pulse, Speedo Pulse, Neutral light
    I lost the instruction page that came with it, im pretty sure they are correct i just want to make sure ive dont nothing daft and got the fuel light wire caught up in it. if they are right then ill have to look at the loom, i have a feeling it may be tight where it goes into the back of the clocks, but while im there and can check ive done everything right. thanks for your help :)
  4. Barstewardsquad
    Hope this helps
  5. rr4tom
    rr4tom New Member
    thanks this is realy useful, i shall check today :)
  6. rr4tom
    rr4tom New Member
    i had the ig live on the wrong wire like a berk lol. rewired and bak up and running shall give the baby a spin today, thanks for your help for the diagram :) cheers
  7. Barstewardsquad
    Glad it helped :)
