  1. Barstewardsquad
    Checked oil, checked chain and checked tyre pressures.
  2. Stimo
    Stimo Member
    Stripped hub and rear brake caliper off vfr nc30 for a nice little cleaning sesh
  3. lambeth longshanks
    Greyskull!
  4. phantom
    phantom Active Member
    looked at the sorry state of it after by brother
    left it home running on fumes and covered in mud.
    I reminded him he needs to sort it out the lazy sod.
  5. hump333
    hump333 Member
    Cleaning mine and chain then off out weather is shining here that god :D
    #2225 hump333, May 26, 2013
  6. callumw
    callumw Active Member
  7. si1000repsol
    Finally got the bike out after winter.
    #2227 si1000repsol, May 26, 2013
  8. GappySmeg
    GappySmeg Well-Known Member
    Spent an hour with a mate checking/setting my sag.
    Rear was pretty good (31mm...... suggested range is 25mm for track up to 32mm for road).
    Front was a bit out (42mm... suggested range is 34mm for track up to 38 for street)... and that equated to 8.5 turns of preload out from full.
    By a bit of trial and error, got the front to 37mm, which equated to 5.5 turns of preload out from full.
    The difference is unbelievable. The bike used to "settle" into a certain lean angle, almost like it had a natural frequency it preferred... which was great if the corner/speed required that angle, a bit tense if it didnt!
    Now though, bike feels like it can take a corner at whatever angle I need it to, it has no natural preference. When hitting bumps the bike feels completely neutral.
    I simply cannot believe it has taken me so long to find the time to do this...... Ladies and Gentleman, CHECK YOUR SAG!!!
  9. el-nicko
    el-nicko Well-Known Member
    Translated with Google by any chance?
  10. Kentblade
    Replaced my Datatool alarm LED that fell apart due to water ingress again.....just very poor quality.
  11. blade1980
    blade1980 Active Member
    Removed half of Scarborough's fly population from the front of my bike!
  12. RRoss
    RRoss Active Member
    Been raining here all day so got a chance to fit my new mudguard:cool: image.jpg
  13. shanes
    shanes Active Member
    hmmm tire changing
  14. Stimo
    Stimo Member
    more cleaning and putting back together , not bad for a 21yr old bike :)
  15. vvtr
    vvtr New Member
    today i stripped all the goodies off my sp2 ready for the big bye bye :/
    carbon hugger, speedo healer, ti akros, pc3, daytona grips & alarm/immobiliser - everything except the grips & alarm have got new owners already :D
    will pay for bling for the new blade, which is due to arrive on thursday. :D
    all im after for now is decent hugger, pilly cowl and tail tidy.... i did try to get the stealer to throw them in but no chance lol... i still feel like ive robbed them tbh (makes a change eh!)
    the oem exhaust can stay for a bit unless something drops into my lap with a pcv or bazzaz!
    i did say the next bike i get will be a quiet one after years of riding big unbaffled vees
    #2235 vvtr, Jun 1, 2013
  16. BlackDevil
    Got the same problem. Where did you buy the replacement part ( LED and wire ? ).?
  17. si1000repsol
    Upgraded the front end with FGRT813 and Brembo M4's. The black clock surround for the 11 Repsol was added with the carbon clock bracket and Harris clipons.
  18. bubba
    bubba Member
    them forks and brembo calipers look sweet mate :cool:
  19. vvtr
    vvtr New Member
    some stuff looks cheap. that doesnt. :eek:
  20. ShinyDiscoBalls
    ShinyDiscoBalls New Member
    Fitted new Dunlop Sportsmart tyres and went for a ride to the Green Whellie Stop in the sunshine.
    Spent the rest of the day removing bugs and polishing her.
