oil light and hesd?????
Discussion in 'Maintenance' started by japandy, Jun 11, 2013.
  1. japandy
    japandy New Member
    hi my problem is that my oil light and hesd keeps coming on, i have check the oil and its ok, i have had the bike for a week and it only starting happening today, any ideas chaps....
  2. blade1980
    blade1980 Active Member
    Is it new, if so get it back to the dealer to let them have a look
  3. japandy
    japandy New Member
    no not new its a 2006 mate
  4. vvtr
    vvtr New Member
    has it recently had a new oil filter???
    ive had this before on kwaks.... the oil filter gets an airlock if you fit it dry, rather than half filling it with oil then fitting it.
    theres a procedure known as 'burping' - with the bike idling, ( preferably on a cold start! ) loosen the filter slightly til oil weeps out then nip it back up.
    the light shouldnt come on again.
    if it's that!
  5. martinowen
    Had a similar problem on my R6 was a faulty temp sensor
  6. wedgiewolves#223
    wedgiewolves#223 God Like
    Mate I had that problem make sure no water on ecu connections under tank cowl mine done it twice ubplug blow and hair drier them
  7. japandy
    japandy New Member
    wedgiewolves u should know it is ur old bike haha, small world......
  8. wedgiewolves#223
    Ha ha no way !!! I washed it with tank cowl off and that happened twice buddy have you washed it today ?
  9. wedgiewolves#223
    I know that bike like the back of my hand buddy if you don't wanna take it too dealer pop past mine the weekend I will sort it
  10. Dougie M
    Dougie M Active Member
    I posted a thread on here a while ago about my HESD light coming on. I took it to the dealer and it was a tiny censor somewhere deep in the bowls of the wiring loom that had gone bad some how :(
  11. japandy
    japandy New Member
    its fine now, must just of been abit of water, i mite take u up on ur offer one day if im stuck or want sum advice mate
  12. wedgiewolves#223
    Anytime buddy
