R+G Bobbins 'NON DRILL' - What does that mean???
Discussion in 'Mods, Upgrades, Accessories and Products' started by blade1980, Jun 12, 2013.
  1. blade1980
    blade1980 Active Member
    Correct!!
  2. kidder1000
    kidder1000 Active Member
    Wanted to get some crash bungs for my 2013 Blade, always go for R+G but don't understand- on their site Aero style bungs = 52.91 ex VAT, while Aero style bungs (NON DRILL ??) = 208.33 ex VAT, Just a slight difference!! Does this mean if I go for the cheaper version I have to drill through the fairing? thanks
  3. Barstewardsquad
    Yep, basically that is it.
  4. dave d
    dave d Elite Member
  5. kidder1000
    Great info big thanks, fantastic video dave d, now understand what I need to do, pretty easy will go for the R+G drill types and save a packet! cheers
  6. Carl
    Carl Well-Known Member
    I've recently drilled my 2011/12 blade, the kit comes with a spiked bolt you loosen off the fairing, do not remove, and replace the engine bolt with the spike, as you push the fairing back the spike makes a dimple on the outside of the fairing, drill a pilot then a 28mm hole with the fairing in place, bobs your uncle! It is very very simple on the newer bikes.
  7. kidder1000
    cheers Carl
  8. sinewave
  9. kidder1000
    will do, thanks
  10. kidder1000
    Ordered drill types, will let u know how it goes!
