Sticky between 3-4k revs
Discussion in 'Maintenance' started by Paulsp2, Jun 14, 2013.
  1. Paulsp2
    Paulsp2 New Member
    Any ideas or tips would be great,
    Iv got a 2007 fireblade and it has a power commander 3 fitted, the more iv started using it iv found that in 1st and 2nd gear in low revs it sticks at the low rev around 3,4 thousand and suddenly wants to take off so i have to do a lot clutch work to release it when riding along at 30 or round bends which isn't nice to manage lol. ANy help would be great Cheers
  2. phantom
    phantom Active Member
    have you still got the rear exhaust flap in place?
    if so is it connected properly and also not sticking
  3. Paulsp2
    Paulsp2 New Member
    I'm gonna have to check that first mate I'm not sure
  4. Paulsp2
    Paulsp2 New Member
    It does have a yoshimura end can if that makes a differnce with the flap question?
  5. martinowen
    That would remove the the exhaust flap, there is another in the airbox though but unsure if this would make a difference, someone will tell you on here
  6. JM1
    JM1 Active Member
    My 06 responded quite well to the intake flapper mod.
    Problem could just be down to your fuel map though.
  7. phantom
    reason I asked about flaps is one sticking would cause the same
    problem.only other time I have heard of something like this was
    a faulty power commander
