Oxford Heared Grips - Removal
Discussion in 'Mods, Upgrades, Accessories and Products' started by beavis, Jun 22, 2013.
  1. beavis
    beavis Active Member
    Fitted these in February and not really used the bike much till my trip to IOM. I can't get on with them as my fingers end up overly stretched on the throttle side. Now I need to get them off. Looked at a few threads on google and most say wd40. Having went out and tried that all it's going to release is the outside rubber grip , not the full grip including the heated element. Any idea folks ?
  2. Barstewardsquad
    Remove the bar end, push a long thin screwdriver between the grip and the throttle/clutch body and keeping it flat roll it around a bit. Spray wd40 into the gap, then twist and pull the grip off.
  3. vvtr
    vvtr New Member
    yeh i took mine off the sp in a similar way..... leave them on for 10 mins so theyre nice and hot, bar end off, poke the wd straw under the grip and give it a good blast.
    may take a bit of twisting but they will come off.
  4. sinewave
  5. beavis
