Best camera to wire wire to bike?
Discussion in 'General 1000RR Discussion' started by hump333, Jun 26, 2013.
  1. sinewave
    Why are some of you bothered if the Filth see it or not?
  2. Garyb
    Garyb Moderator.
    Sorry Dude. Guess we get carried away.
    My Off topic posts now removed :)
    #22 Garyb, Jun 27, 2013
  3. Pete H
    Pete H Active Member
    I use one of these on occasions, it's waterproof to a depth of six feet so its ideal for yorkshire! And they're only £120 new now.
    It's not the most glamorous or Gucci looking bit of kit, but it has built in image stabiliser and mic wind suppression, so I tend to only get engine noise from it rather than rushing air.
    Mounted using this:
  4. Muffking
    Snap. I think they're pretty good.
    I think the real issue is getting at the memory card and powering it.
    Have you thought about bullet cams as the feed and supply should be on cables that can go in through the bulb holder.
    Here's an after thought. Could a H7 bulb be butchered in order to fit a bullet cam in the high beam headlight?
    #24 Muffking, Jun 27, 2013
  5. hump333
    hump333 Member
    Muffking l have projector lights [​IMG]
    Was thinking something along your lines but running the wire/usb out bottom light to power from dip light 12v and make lightweight bracket to hold what ever need holding. I've got blue print in my brain of what I want.
    I Need small cam and all the bits n bobs to get the plan rolling. :)
    Your cam looks good.
  6. martinowen
    I still want some of them lights when I have some cash spare :D
    Looking great hump
  7. martinowen
  8. hump333
    hump333 Member
  9. martinowen
    I better get saving then really! Are the 04-06 lights the same?
  10. Muffking
    Unfortunately not. Ive got rr6/7 headlight protectors on my rr5 and they're a different shape in the top outer corners.
  11. martinowen
    I Best find a spare light too then :)
  12. Tinks
    Tinks New Member
    Excellent movie & picture quality. It's amazing how much movement the rear wheel travels up & down yet the bike still looks stable.
  13. hump333
    hump333 Member
    04 to 07 are 100% the same lights.so are 2008 to 2012. Then they change late 12 to 2013 :)
  14. hump333
    hump333 Member
    Lights are same on o4 o7 the nose cone is different shapes comes out more on o6 / o7 than the o4. ;)
  15. sinewave
    Has anyone noticed that the dipped headlights in Pic 3 show the HRC Blade with the offside light lit and yet the Repsol behind has the nearside light lit?
    Why would they change this between UK models unless the Repsol is an import or was built for a country where they drive on the right? :confused:
  16. Muffking
    It could just be the headlight protectors that are different then, as i seem to remember there being an 04-05 & 06-07 when i went shopping for mine.
  17. Muffking
    Yeah i made a mention in the post. Ive no idea why they are different, but its Lee's white blade that lights up on the other side. All the others ive seen including mine light up on the N/S.
  18. martinowen
    All the hrc's in those pics are the wrong way, and Gary's bike too ??? That's weird
  19. martinowen
    Hump I don't know how good you are with electrics but you could do with butchering an iPhone and using that camera or trying to find who supplies them or something
  20. hump333
    hump333 Member
    My rr5 was left hand side as well and right full beam. Until I upgraded to bi xenon projector.
    Martin thats good idea mate:thumbup: has anyone got iphone 4s or 5 that wants to get on the back of my blade see what its like at 160++ :eek:
