Where to put lower heat shield ????
Discussion in 'Mods, Upgrades, Accessories and Products' started by stev1456, Jul 2, 2013.
  1. stev1456
    stev1456 New Member
    Just purchased a carbon lower heat shield from Powerbronze.
    I can't for the life of me find where to attatch it. The two attatchment holes don't seem to line up together with anything on the bike.
    Do i need to remove the metal heat shield ? If so, the rear set has an attatchment to this ??
    Anyone got any ideas ?
  2. phantom
    phantom Active Member
    Should fit into the original holes.
    Mind you I cut the alloy cover on mine in half and painted
    The lower bit black to blend it in a little.
    #2 phantom, Jul 2, 2013
  3. phantom
  4. Barstewardsquad
    The original one has been taken off mine, but that is an Akra one. From Phantom's pic I reckon it needs to be removed.
    Click on pic for a bigger image.
  5. martinowen
    Fits over the metal one
  6. stev1456
    stev1456 New Member
    Thanks for the replies.
    Just gone out there and had a look - the bottom of the shield is blocked by the metal marked by the yellow arrow.
    This seems to be the rear set attatchment to the metal heat shield - can this attatchment be taken off and if so i'm assuming that there is a hole for the lower part of the carbon shield ??
  7. martinowen
    I have stock rear sets that may be your issue
  8. Muffking
    Yep that's the bit I drilled & tapped on mine.
  9. stev1456
    stev1456 New Member
    Thank you Thank you
    Now i know why it won't fit.
    Guess i'll have to get the drill out :-(
  10. Muffking
    No problem Stev, that's what the forum's for, picture whore'ing :D
    So here's another after i chopped the old brake reservoir off and fitted the same one you have.
  11. stev1456
    stev1456 New Member
    Finally got it on - just gotta get some better bolts for the fixings
    Thanks to all for your help
    Steve
