Road bike to track bike advise please.
Discussion in 'Trackdays' started by Jase, Jul 3, 2013.
  1. Jase
    Jase Elite Member
    So I should get my painted track fairings back next week so plan to strip my bike down ready for fairings and conversion to track bike .
    I am planning to put a day time mot on it so will keep the horn but tape up/cable tie up all lighting wiring etc.
    What do I do with the air intakes as at the Moment they fit to the road fairings but as track fairings are pretty basic there is nothing to attach them to .
    While I have it stripped down I will remove rear pillion pegs.
    My plan over the winter is to either fit full brembo brake kit or ohlins suspension which would you do first as its not a cheap upgrade.
  2. thefirebloke
    thefirebloke Elite Member
    Nothing wrong with the brakes, fit the Ohlins!
  3. Si.
    What he said.
  4. thefirebloke
    What about a big bore kit.......might make you go a bit faster! :D
  5. Jase
    Jase Elite Member
    I get terrible brake fade on track where my brake lever is nearly touching my throttle grip but have just replaced the front pads with EBC sintered hh pads so will see how they are,I have braided lines so will see what difference there pads make.
  6. scooby
    scooby Elite Member
    suspension 1st every time,but a better m/c will help with your brake fade,well either that or brake less ;)
  7. Jase
    Jase Elite Member
    Just priced up full brembo set up fecking hell there not cheap ,will get new MC and brake less.
    Any ideas on air intakes what to do with them on track fairings ?
  8. Si.
    jason, you can buy just the intakes in carbon. Ebay come up often with them, around £100.
    search cbr1000rr carbon or cbr1000rr intakes.
  9. wedgiewolves#223
    wedgiewolves#223 God Like
    Buy intakes standard ones are just meant for road fairings you can use them but too many tabs etc to break off . Www.crcfairings.co.uk suspension first then brakes then the list goes on buddy when the bug has bit a chunk out your arse lol
  10. RichC
    RichC Active Member
    Just buy a two grander on ebay and save your Fireblade for rides out with the lads.
  11. Jase
    Jase Elite Member
    Too late i stripped all the fairings/lights etc off today ready for the track fairings I removed the rear pillion pegs while I was at it , but I plan to put a daytime mot on it so u can still use it on road .
    Question I have on each side you have the air intakes inside those you have a silver valve thingy which has a breather pipe and a electrical conection do I need to refit these as not sure what they do as bike seems fine without them.
  12. Si.
    That's the PAIR system. You can remove it all Jase.
  13. Jase
    Jase Elite Member
    So can I remove the pipe also that disappears in to the engine as well
    What is there purpose anyway?
    Cheers Si
  14. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Repsol paint job?? ;)
  15. Repsol Rob
    Repsol Rob Elite Member
    TT LEGENDS !.....
  16. Jase
    Jase Elite Member
    TT legends with a wsb flavour .Sexy or what :D
  17. Si.
    Here you go:
    ROGUE RACING CBR1000RR Intake Flapper Valve page
    its not the pair system, it's the total flapper removal, silly me. Lee and I did mine as I have a pcv, and the bike was mapped with it removed/blanked off in the airbox.
  18. sinewave
    What Year is ya Bike OP?
  19. Jase
    Jase Elite Member
    2009
