Problem with trackbike
Discussion in 'Trackdays' started by Yorkshire Tyke, Jul 25, 2013.
  1. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Eyup peeps
    GOt an issue with the 750 that reared its head last time I was at cadwell..
    When the bike has been switched off in between sessions and then started it fires up nice and idles absolutely fine
    But when setting off for assembly area in 1st it picks up a little then seems to cough/miss which jerks the bike and then it picks up again and goes, only time its done it any faster than that was on the pit straight where it did it straight after changing gear and only did it once.
    Where's the best place to start looking??
    I was gonna change the plugs and see how that goes, it has a power commander and custom map so dunno if its a bit lumpy or rich in low revs first gear.
    The exhaust is slightly loose form the link pipe but not enough to allow any gasses to escape and its still secure on the bike.
    SO dunno...??
    Any pointers/ideas much appreciated
    TaTAR!!
  2. wedgiewolves#223
    wedgiewolves#223 God Like
    Hi buddy firstly I'd take off power commander and try this will illiminate the PC . Then gixers suffer with coils 1 on every plug so would be a case of getting one and swopping 1 until its fine other than that mate usually bullet proof . Also bang a set of plugs in it while you in there
  3. wedgiewolves#223
    Also airfilter is gonna be k&n or similar give it a clean and oil eliminate all the air/fuel first
  4. Yorkshire Tyke
    Yeah cheers wedge i'll try the air filter and disconnection of the PC first, unlike my balde with the PCV under the seat I dont know where it is on my trackbike I've had tail fairing off to get to battery and can't see it anywhere round there?? Unless its further down. hmmmm...
  5. wedgiewolves#223
    Only usual space like you say is in the tail fairing or some people root them by the clocks id lift tank and just follow wiring off injectors . Or even there will be a negative wire on the battery see which way that is heading
  6. Yorkshire Tyke
    Yeah ill follow from ground wire good idea batman. its full system for exhaust so can only imagine it running like shit if disconnectes but atleast it would eliminate bad fuelling. cheers wedge!
  7. martinowen
    Sounds similar to when I pinched my fuel line when I lowered my tank
  8. wedgiewolves#223
    Good call i have also done this run fine until i was on the beans
  9. Yorkshire Tyke
    Yeah ill check that when i lift the tank mate. Cant imagine it being a pinched fuel line if its only happening at slow speeds although id guess thatbwhen you go quicker more air=more fuel flow??
  10. martinowen
    Mine was fine until I gave full throttle from slow speeds, almost threw me over the bars a few times!
  11. samd1985
    samd1985 Active Member
    Possibly worth checking the throttle position sensor is functioning correctly if the above advice doesn't work. I had similar misfiring/jerks/sudden brief loss of power when the TPS went; admittedly on my car. I had an aftermarket ECU so was able to plug the laptop in and graph the sensor outputs. It would spike down to a zero throttle reading briefly despite me being on the throttle, and as a result the ECU then chopped the fuelling to suit the false readings. It felt just like a misfire and was intermittent, and normally as I throttled on slightly
    Hope that's of some help. Might be totally irrelevant but worth adding to the list
    Sam
  12. Yorkshire Tyke
    Thanks everyone for the input. Sam, I will try the TPS if all else fails.
    Gonna have a look over this on tuesday night with a mate accompanied by a ruby and a few tins getting ready for the 1000rr choo choo at oulton!!
    :D
  13. Yorkshire Tyke
    Ok ive had a good go over the bike. Disconnected the fuel injection module and no issues. cleaned the air filter (didnt need much). checked plugs and theyre good as new. fuel lines were free no signs of being pinched. tps looks ok. ive wd40d as many connectors as i could see incase water had got in anywhere. so dunno what else it could be??
