What OIL are you running ?
Discussion in 'Maintenance' started by BladeWitch, Aug 3, 2013.
  1. BladeWitch
    BladeWitch New Member
    What Oil are you running in your CBR1000RR at the moment ?
  2. honda.ima
    honda.ima Active Member
  3. Muffking
    +1
  4. PeterT
    PeterT Active Member
    Me too
  5. SIDEWAYS
    SIDEWAYS Senior Member
  6. barry107
    barry107 Active Member
    Same as everyone above, also run it in my track 600rr.
  7. Repsol_Dan
    Repsol_Dan Active Member
    Shouldn't this be called "What oil are you burning"???
    But +1 for me
  8. kev.b
    kev.b Well-Known Member
    Same here !
  9. phantom
    phantom Active Member
    same here ;)
  10. Ian E
    Ian E Active Member
    Me too, in both Blades :cool:
  11. Kentblade
    Ahhh. Swimming against the fully syn tide, use Castrol semi syn, always used it in the race bikes as well, but that was dropped after every meeting.
    Have used it in the last 4 Blades, that have combined mileage of close to 250k, never changed a shim or had any issues.
  12. BladeWitch
    what do you guys think about the honda oil HP4 & GN4 opposed to the castrol ?
    also - ive just tried the motul 300V and not sure i like it or not.
  13. HRCTrev09
    HRCTrev09 Well-Known Member
    Silkolene Pro4 Energy 10w30 and K&N Oil filter :) It's more expensive but you get what you pay for!!.. much smoother with a silky gear change and low drag! SWEET!!! :D ;)
  14. sinewave
    Mine runs Semi over Fully Synth, can't remember the reason given by the Dealer now?
  15. BladeWitch
    how about the honda manual recommended oil = honda HP4 or GN4 10w30 versus other brands - any comments people ?
  16. dogman
    dogman Member
    We cant get silkolene pro 4 in Australia, but we can get silkolene comp 4 10w40 which I use and I reckon its OK but I dont leave it in for much more than 3000Kms.
    The castrol power 1 racing we get here is 5w40, and I have used it but not impressed really. Seems to break down fast giving notchy gearchanges.(just my opinion)
    Motul 5100 semi is a fairly good oil without going over the top price wise.
    Its all a bit subjective, really.
  17. thezipsteruk
    thezipsteruk Elite Member
    another +1 from me too, only difference is the filter. Changed for a K&N filter just because of the simple brilliancwe of putting a standard 14mm nut on the end of it to torque it up and undo easier!!
  18. MrB
    MrB God Like
    Silkolene Pro4 10-40 or Castrol Power 1 10-40
  19. HRCTrev09
    Hi mate,
    Yeah I felt that Castrol Power 1 wasn't up to much and found my gearchange notchy!!! I much prefer Silkolene to Castrol!
    Pity you can't get it over there:( Strange to us using different viscosity due to a different climate :)
  20. Givover
    Usually use the Castrol power 1 race but last time I banged in the Silkolene Pro 4 seems good and its a lovely red wine colour at 50 sheets per 4 lts its not cheap but there again its the price of a curry for two and you know where that ends up .:eek:
