2008 Black CBR1000RR Fireblade - Ohlins Ktec Yoshimura Quickshifter thousands spent
Discussion in 'Bikes For Sale' started by 08blade, Aug 1, 2013.
  1. 08blade
    08blade New Member
    My pride and joy 2008 Fireblade in black with thousands of pounds worth of extras is up for sale
    I purchased this bike in standard form from a mature honda fanatic who owned the bike from new. just had the all important crankshaft recal under honda warranty 500 miles ago, valve clearance done at same time and most importantly this bike does not burn oil like some of the blades out there ive never had to top up inbetween services.
    Long MOt, tax, v5 spare keys and fobs all present
    18k miles with full Honda service history, valve clearance, oil service, clutch cable and new crankshaft/main bearings/big end bearings/rod bolts just carried out 500 miles ago
    Bike was completely standard till 17k miles, thousands spent spec includes:
    Ohlins TTX mk2 rear shock
    Front forks off a 2011 HRC blade that had 2k miles - with full Ktec internals: full piston kit/control valves/springs/new seals with after marker adjusters done buy 100% suspensions
    Brembo 19x18 master cylinder fitted with brembo reservoir and brakelight switch for road
    Yoshimura R77 carbon exhaust with decat
    Quickshifter - comes with push and pull type sensor so option for race and normal shift style (1up5down and 1down5up)
    GB Moto rearsets
    Digipro gear indicator
    Pazzo clutch leaver
    EBC HH pads
    Gilles chain adjuster
    Renthal sprockets 2up rear only
    Renthal grips
    Evoteck alli axel nut
    R&G engine cases
    Stomp grips
    metzler racetec tyres with good tread
    all the usual crash bungs, screen, tail tidy, reels, intergrated tail light etc etc
    all original parts included. there are probably other bits that ive missed but that list above comes to around £3000
    pics do not do the bike justice these are all i have on the phone at the moment with all the above mods:
    £6500 as it is
    pm me if your interested or need a contact number
    Thanks for veiwing
    #1 08blade, Aug 1, 2013
  2. RichC
    RichC Active Member
    Would it be possible to email some pictures of the bike in daylight? [email protected]
    Dont guess you would be interested in a ZX6RR track bike in part ex??
  3. thezipsteruk
    thezipsteruk Elite Member
    how can you let her go mate?? :confused:
  4. 08blade
    08blade New Member
    I know what you mean but i maybe betting a new bike through work just cant justify two bikes and a scooter
    Richc il try get some better photos during the day for you asap
    Thanks
  5. 08blade
    08blade New Member
    Few more pics added from today without washing it
    #5 08blade, Aug 3, 2013
  6. 08blade
    08blade New Member
    5500 now with stock rear shock And front forks
    Might have ohlins ttx2 rear shock and the front forks up for sale
