First gear bang!!
Discussion in 'Maintenance' started by grambo, Jul 28, 2013.
  1. grambo
    grambo New Member
    Need a bit of advice here, when engaging 1st gear on my RR8 it goes in with a hell of a bang!!!. I bought the bike 3 months ago,16860 miles on her but has full sh.
  2. Givover
    Not sure about The Bang but all 1000 cc bikes have a fair old clunk when 1st is engaged .
  3. martinowen
    How's your chain tension? I believe this can affect it
  4. scooby
    scooby Elite Member
    most bikes will crunch when you select 1st when cold,usually gets better when the bikes warm as it's not revving as high and clutch plates are free'd up a bit more
    shouldn't be anything to worry about as long
  5. grambo
    grambo New Member
    Cheers guys.....chain tension is right enough martin, ....i will let it develope !!
  6. Only1Matrixxx
    Only1Matrixxx Active Member
    That's how we know we ride a Honda!!! Best you can do is ensure chain tension is correct as said above...
  7. kev.b
    kev.b Well-Known Member
    Hold the clutch lever in for a few seconds before selecting gear when first started an engine oil is cold . Selects gear much smoother . All bikes clunk a little when selecting first , correct chain adjustment is key .
  8. kpone
    Yep, always makes me flinch when the engine's cold. My 550f's exactly the same. Maybe it is a Honda thing.
  9. borat
    borat Active Member
    Happens when engine is at 95+C in today's heat.
  10. phantom
    phantom Active Member
    bang engaging first, welcome to honda ownership lol
  11. masterblader
    masterblader Active Member
    Honda clunk when cold is the norm. Try blipping the throttle like you do when changing down, it speeds up both input and output shafts to ease the engagement.
  12. BladeWitch
    BladeWitch New Member
    yeah, 1st is always a bit of a jolt to the ole system when you select it.
  13. Kentblade
    Sitting daily at the traffic light GP that is London commuting, as everyone prepares to launch as the opposite lights start to change to red, bikes are all nicked into 1st quietly, then bang goes the Blade, dont matter hot or cold, everyone knows when a Blade is there.
  14. phantom
    ever get the drivers turn round quickly when you select first at the lights :D
  15. kpone
    It does tend to make them glance over and lick their lips, Ciaran...
  16. phantom
  17. Toy40
    Toy40 Active Member
    Hold in the clutch for a few seconds and it goes in smoooooth as silk..RR5
  18. T-u-R-b-O
    T-u-R-b-O Member
    :eek: THAT really works! :eek: great advise :cool:
  19. phantom
    not on the newer ones...well not mine anyway
  20. travellingkiwi
    travellingkiwi Active Member
    Mine either. Just live with it. It's not actually much louder than anyone elses... It just feels that way because you're closer to it
    H
