Fitted a Slip On - Power Commander/Bazza Or Not
Discussion in 'Mods, Upgrades, Accessories and Products' started by JimGreen, Aug 24, 2013.
Bothered with a PC/Bazza Or Not........
  1. Fitted a PC/Bazza
    71.4%
  2. Not Fitted a PC/Bazza
    28.6%
  1. JimGreen
    JimGreen Active Member
    Just trying to get an idea of how many people fit Slip On Exhausts, and if they then fit a Power Commander/Bazza or not ????
    Fully appreciate that in order to make the most of the mods, a PC/Bazza and ideally a dyno set-up can achieve this, but how many people just run with the Slip On and have no fuelling issues.
    #1 JimGreen, Aug 24, 2013
  2. Givover
    Hi Jim I have had my share of bikes and always fit an end can .I don't fit power commanders or the like but I always feel that the bike runs a little rough without also yesterday when I was out I came to a bend and just eased the gas on an the bike lurched for a second which is not ideal .I will be having one fitted on the next bike and mapped .
  3. Slick
    TBH my vote was based on a CB1000R with a Leo Vince slip on and decat. Pre PC a little lumpy, you really notice the difference once one is fitted.
    I remember being a leaned over position at quite low speed and the engine kinda chugged for a split second but enough for me to nearly drop the bike, PC sorted that out!
    Only gained a few ponies at peak RPM but the silky throttle response and gobs of extra mid range torque was like WOW.
    Got the PC fitted to my otherwise stock Blade, a little smoother down low especially as now the O2 is eliminated. Plan to add an auto tune shortly and maybe a yoshi if funds permit.
    #3 Slick, Aug 24, 2013
  4. explorer
    explorer Member
    I fitted a yoshi slip on, and it runs a bit rough upto about 4000rpm, then it's fine. Going to fit a PCV and then see what it's like with the stock yoshi map from the PCV. Then depending what it runs like might have it on a dyno and have it mapped.
  5. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    The stock yoshi map is baba
  6. JimGreen
    Not Good Then.......LOL
  7. explorer
    explorer Member
    Looks like its a dyno then
  8. JimGreen
    Bump..............
  9. dogman
    dogman Member
    The thing with this bike is that when you remove the muffler, you are also removing the cat, and this will affect the fuelling more than if the cat were to remain, and you were just swapping an end can like on some other bikes.
    Just my 2c I think the maps on the dynojet website are not too bad, works OK for me.
  10. Remal
    fitted a BAZZAZ when I had a yoshi fitted
  11. madmac
    madmac Well-Known Member
    Fitted a PC to my previous bike (CBR600F). The bike wasn't too bad with just the end can, but as soon as I also fitted a K&N filter - it was clear it wasn't running right. The PC smoothed that right out with an existing map from the PC website for my end can.
  12. nambiker
    nambiker Active Member
    after my results from fitting and tuning a bazzaz on my blade this week i highly recommend it! my bike runs so much better and i gained more torque and power!
  13. JimGreen
    Proves that fitting is slip on is good, but adding a PCV/Bazza makes it work as it was intended.
    But.......... Some people just do it for the sound, some do it to get the most they can out of their bike.
    Still good to hear that it's not a necessity though, and you can fit an aftermarket slip on without too many issues and "don't have" to fit a PCV/Bazza.
