Key question-cbr 954
Discussion in 'Other Bikes' started by timmy twoshoes, Sep 4, 2013.
  1. timmy twoshoes
    Hi just a quick question.
    Does anyone know when you get a new key cut does it have to have a transponder in it for the HISS immobiliser
  2. sps170373
    If the bike has HISS fitted it will need a coded key to start it
  3. timmy twoshoes
    In relation to the answer how do you Obtain a coded key
  4. sps170373
    Pop into any Honda dealer and they can order a key and get it cut, they will then have to code it to the bike! Takes about 15mins for them to do.
    Phone around though as the price can vary quite a lot. I got it done on my 954 I had a few years ago as when I bought the bike it only had one key
  5. lambchops
    lambchops Elite Member
    Is it right the US models don't have the HISS? So If I buy a US ECU shouldnt have to worry about this right?
  6. sps170373
    Not sure on the USA versions having HISS but the ecu's might not give full power like ours do due to emissions etc
  7. sps170373
    Besides is probably still cheaper for a new key to be coded by Honda than a second hand ecu that you don't know the history of!
  8. JM1
    JM1 Active Member
    The US models don't have HISS. The US bikes are restricted via ignition retard and some (eg, California) have additional emmissions related stuff.
  9. timmy twoshoes
    Just checked with Honda, £85 for new coded key - Robbing gets
  10. ShinySideUp
    ShinySideUp Elite Member
    Some key cutting shops like timpsons can cut and code your key but not sure how much they charge tho.
  11. sps170373
    Did you try just one place or a couple? Am sure mine was half that price
  12. Hudson
    Hudson Active Member
    That is a lot, get another quote. When i got my 954 it also only had one key, i got another one cut then took both keys to my local Honda dealer, they charged me about £30 to code it, took about 10 mins
  13. mcrb
    mcrb New Member
    When I broke my key i ordered new for around 30$ cut for few$ and simply swap this little thing from broken key to new one
  14. timmy twoshoes
    Don't have a broken key - only have one key
  15. glynn
    glynn Member
    That's cheap compared to landrover who want £220 for a new key and alarm fob. They are proper robbing f@?!/?!
