What Tyre Pressures do you Run ?
Discussion in 'Maintenance' started by BladeWitch, Sep 8, 2013.
  1. BladeWitch
    BladeWitch New Member
    What Tyre Pressures do we all run ?
    Front & Back / Track Vs Road / Winter Vs Summer / Single Rider Vs With Pillion / Jolly Vs Pissed
    #1 BladeWitch, Sep 8, 2013
  2. daddy2coull
    daddy2coull Active Member
    i only ride a 600rr, but low to mid 30's for the road
  3. Slick
    Front/rear
    Road 34/ 34 cold
    Track 30/30 hot
    seems to work well for me:)
  4. BladeWitch
    tyre pressures for a cbr600rr are the same for a cbr1000rr and yeah, never say "only" 600 as they can eat a 1000 in the corners for breakfast.
  5. sps170373
    I'm running 34 front and 36 rear on my Pirelli DRC and the same on my Michelin pilot pures
  6. JimGreen
    JimGreen Active Member
    I run 34f and 38r for the road. Certainly seems to handle better than the pressures shown in the user manual, which I believe are 4psi higher than I run.
  7. Andy
    Andy Active Member
    34 Front & 38 Rear for road use on Michelin Pilot Power 2ct, just makes it feel more planted when cornering
  8. sinewave
    36F 34R (Cold) on the Road with Pirelli Rosa Corsa's
    28F 24R (Cold) on the Track using Metzeler Racetec K2's
    35F 30R (Cold) on the Track using Dunlop KR393 Wet's
  9. phantom
    phantom Active Member
    normally 34f/36r, for spirited riding 34f/32r and I dont take pillions.
  10. BladeWitch
    WHAT! you dont take rear prisoners - you mean you dont ride a CBR1000PV (PV = passenger vehicle) instead you ride a CBR1000RR (race replica) like me - all hail the RR.
    #10 BladeWitch, Sep 9, 2013
  11. BoroRich
    BoroRich Elite Member
    36F / 42R as per the manual.
    I always was a conformist :D
  12. BladeWitch
    interesting how some of us run harder psi front, others harder in the rear
    i run 35psi front 35 psi rear for mountain roads but just about to drop the rear psi to 31 and give it a feel
    (pirelli rosso corsas)
  13. samuk
    samuk Well-Known Member
    38 rear
    36 front
  14. phantom
    for my tyres michelin recommends 36F 42R for road and 30F 24R for tracks but I found the 36/42 too hard on the
    roads over here.
  15. BladeRR8
    BladeRR8 Active Member
    Which Michelins are they ?
  16. BladeRR8
    Interested to hear how you get on
  17. navvy10
    navvy10 Well-Known Member
    I run 36/40 on my Michelin 2ct's
  18. Remal
    34 front and 34/36 rear cold As low as 30 front and rear Hot on track so more like 26/24 rear
  19. BoroRich
    I found that until I got my suspension setup done. Then it was fine.
  20. BlackDevil
    Front: 36psi
    Rear 42psi
    worked fine with me....
