Mancave specified and ordered
Discussion in 'Lounge' started by Freedom of choice, Sep 18, 2013.
  1. Freedom of choice
    At last I have pulled my finger out and the new bike garage /man cave has been specified and ordered:
    12ft x 10ft timber framed structure
    Wide double doors hung on 3 heavy duty hinges, the centre one reversed to prevent lifting. 5 lever lock and two heavy duty padlock padbolts fitted top and bottom, the inside of the doors will also have a solid horizontal timber plank fitted into brackets to stop the doors being forced open.
    Flooring with 50mm insulation below 12mm exterior grade flooring
    Walls and roof insulated with 40mm foil backed Celotex/ Kingspan then internally boarded with 9mm plywood
    Side door with 5 lever lock and additional heavy duty padbolt.
    Double fixed window with internal twilweld mesh grill
    All external bolts will be coach type to prevent some little scrotum trying to unbolt the doors.
    First fix wiring for Alarm, heating, power sockets and lighting
    A matching side gate with 5 lever lock and fencing is also going up.
    With a bit of luck it should all be up and serviceable by mid to end of November. Should be nice and comfy for the Panigale and still plenty of room for a "project"
    L has already commented that she is surprised I haven’t ordered a flat screen tv, sofa, wallpaper and curtains for it.
  2. kpone
    Sounds funky David. And living out there you'll have no shortish of Amish brethren to help when raising day comes.
  3. arthurbikemad
    Your spec sounds great! BUT DO get the TV or you could miss some racing when cleaning the 1199!
    #3 arthurbikemad, Sep 18, 2013
  4. martinowen
    I can't wait for the kids to move out so I can have a man cave again
  5. kpone
    We've just renewed the planning permission we got to build a double garage with workshop space above, just before Jeanette was made redundant, so I've started salivating on what could be again. It all boils down now to whether I've got a job in the Spring when we want to break ground on it.
  6. The.kickboxer
    The.kickboxer Active Member
  7. SimonRR
    SimonRR God Like
    Sounds good and safe :)
  8. Remal
    Does sound nice david
  9. Jimbo Vills
    Sounds great David, although, you haven't actually ordered it without pictures!! ;)
    Love to build my own place so that I could go to town on the garage spec, it'd be the 1st thing to be completed lol
