Huge Screwdriver
Discussion in 'Maintenance' started by JM1, Oct 2, 2013.
  1. JM1
    JM1 Active Member
    I need a big screwdriver (and I mean big compared to what we normally use for bikes etc), but am having trouble finding something.
    Anyone got any tips on where to get one?
    P.S. This is because I have butcherd a seized bolt by slotting the head, but the slot is big and now I need a screwdriver to fit it.
  2. martinowen
    Do you mean you have chewed up the head?
    If so place an elastic band flat over the head and then put the screwdriver onto that.
    This gives it a good grip in the head and will come undone with ease
  3. phantom
    phantom Active Member
  4. The.kickboxer
    The.kickboxer Active Member
    Isn't that what mole-grips where invented for, that and making a vice in ur workmate
  5. The.kickboxer
    These are also handy if you rounded the head on a bolt, if you cant undo with a spanner u have no chance with a screwdriver.
  6. t0m541
    t0m541 Senior Member
    Photo ?? a picture paints a thousand words as the saying goes ;-)
  7. Remal
    No help but
    • Like Like x 6
  8. t0m541
    Hahahahahaha ^^^^^^^^
  9. JM1
    JM1 Active Member
    It's an allen head. I chewed it up with a hex key. Then I slotted it with a dremel. I now need a huge screwdriver because it's not accessible enough to use anything else.
    I'm going to try the elastic band and quite large screwdriver suggestion though :)
  10. JM1
    JM1 Active Member
    P.S. It's a Hornet no. plate holder/undertray bolt right inside the rear storage area.
  11. JM1
    JM1 Active Member
  12. arthurbikemad
    Mmm, sometimes a dot punch also works to drive them round, before the slot Id have used a star or torx star is better... pita that!
  13. kpone
    Military surplus outlets often have monstrous sized versions of normal tools on display.
  14. kpone
  15. Garyb
    Garyb Moderator.
    JM1, If all else fails and you can get a drill to it? There's easy outs 'screw extractors' around £15 a set, got be out the poo on a few occasions.
  16. t0m541
    That will tap round with a small nail punch or similar, I come across this situation quite often at work. The tapping will loosen and corrosion and get it turning.
  17. JM1
    JM1 Active Member
    Thanks gents, sounds like an extractor for me, or a nail punch (but I don't know what that is yet!)
    Not sure why it's stuck - bike is nearly new, no corrosion at all in the area. It was just really tight with a very shallow head in a confined space (that's my excuse anyway).
  18. JM1
    JM1 Active Member
  19. JM1
    JM1 Active Member
    Oh wait sorry, I do know what a nail punch is now that's I've seen a pic of one on google :)
  20. phantom
    I had bolts like that stuck before, they used generous amounts of
    thread lock along with the odd bit of damp in there made it a right
    nightmare to remove.I drilled the center and then used a punch to
    get it out.
