Optimate Charging
Discussion in 'General 1000RR Discussion' started by bradt, Nov 21, 2013.
  1. bradt
    bradt Elite Member
    If laying the bike up for a few months, should the Optimate charger be connected on a permanent basis, or just a few hours every week
    I do intend to get out on the bike, when the roads are dry, but not when covered in grit/salt
  2. navvy10
    navvy10 Well-Known Member
    "Charge maintenance: during alternate 30 minute periods, at a float limit of 13,6V the battery is offered charge current (up to the maximum) it needs to sustain it against any small connected loads or power leakage and against natural self-discharge. OptiMate 5 can stay connected to the battery indefinitely and the battery will stay cool and safe. And optimally charged. Of course."
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    Both my bikes are always on trickle charge and always have been
  4. Pete H
    Pete H Active Member
    Mines connected every time the bike is stationary at home, be that overnight or when I'm away on a holiday, does it no harm at all as the whole principle of the optimate is not to have to worry about it being connected and cooking the battery.
  5. Swiss T
    Swiss T Active Member
    Me too; connected all the time whilst in the garage. I have done this for years & never had a battery problem.
  6. Remal
    Mine is also connected when not in use the same as the kit car. both Optimates (model 2 and 4) are mounted on the roof for easy connections when parked. having done this for the last 5-6 years it's never been a issue
  7. kpone
    As above, Brad. The bike gets rolled into the garage and plugged into the Optimate out of habit. It could be there overnight or for a month.
  8. Barstewardsquad
    No electrickery in my garage but I leave mine permanently connected to a solar panel charger. Always used to leave mine connected in old place where I did have a supply amd never had a problem.
  9. kpone
    How effective do you find the solar charger, B?
  10. Dec
    Dec Active Member
    Yep, I'd be interested to know too Barstewardsquad as I have no electricity in the garage either.
  11. Nutty Tart
    Nutty Tart Well-Known Member
    +1 ^^^ love to know what panel you are using and how good is it at maintaining the charge
  12. Barstewardsquad
    I use this one from Maplins. I had it in a north(ish) facing window last year and the bike started first time despite being sat there from about Oct to March/April.
    One tip is to try and tie it somewhere secure as the rubber suction pads aren't the best.
  13. Dec
    Dec Active Member
    Topman! Only a tenner at the mo.
    Thanks Bar
  14. Mattlong
    Mattlong New Member
    Mines connected all the time whilst parked.
  15. sinewave
    Got my Optimate 4 screwed to the garage ceiling then the charge lead just drops directly down to the Bike when it's on it's stands.
  16. arthurbikemad
    We should do a show us your optimate thread :)
  17. sinewave
    OK, U Win Art! :rolleyes:
  18. wedgiewolves#223
    Ok Arthur billy big balls lol that's a nice line up !
  19. Dec
    Dec Active Member
    That's just showing off sinewave
  20. arthurbikemad
    Sad thing is I have three more of the fekers! :(
