Optimate Charging
Discussion in 'General 1000RR Discussion' started by bradt, Nov 21, 2013.
  1. Nutty Tart
    Nutty Tart Well-Known Member
    No point having another thread ....... you win with this setup ......... very nice :cool:
  2. Hudson
    Hudson Active Member
    Impressive line up.... on this subject is it worth changing an older Optimate for one of the newer all singing all dancing ones ???
  3. Freedom of choice
    No one likes a show off Arthur, but as it's you.....nice one fella.
  4. kpone
    Still, as a Christmas tree, it's shite...
  5. Pinkster1000RR
    Pinkster1000RR Active Member
    I was away for 10 months and i left mine on and no problems :)
  6. Andy
    Andy Active Member
    I will be leaving mine permanently plugged in when the bikes in the garage
  7. sinewave
    This threads reminded me to order another Opitmate 4 off Andy for me Tracker over winter! :)
  8. Dec
    Dec Active Member
    Tracker for the Blade? Which one?
  9. sinewave
    'Tracker' as in my ZX10 Track Bike!
    The Blades already got an Optimate so I'll be screwing another to the ceiling for the Kwak!
    Can't av me Green Meenie being left out now can we?
  10. GSP
    GSP Active Member
    I bought a new lead the other day for mine but the bolts on the battery seemed to short for the extra 1 or 2mm of metal loop.
    Bike is a 2013, I need to try again :-(
  11. PeterT
    PeterT Active Member
    I had the same problem as I also put heated grips on straight to the battery, I used stainless steel bolts that were slightly longer. It is a metric thread.
  12. morpheus20170
    morpheus20170 Active Member
    I hope I'm wrong but I think my Optimate is showing Yellow and Green lights again which last time meant I needed a new battery.
    I have a datatool alarm fitted, QS and GI but wouldn't have thought that would matter, would it?
    Thoughts guys please. New battery fitted within last 6 months.
  13. samuk
    samuk Well-Known Member
    Is there a easier way to connect this without having to remove the seat? or do you all remove the seat to connect the charger every time?
  14. sinewave
    You only remove the seat the once Sam to connect up the quick fit connector.
    You then run this connector to wherever you see fit for your particular bike for ease of use.
    The best place I find on a Blade is to have the connector poking out of the small triangular outlet in the Bikes frame as seen below on mine.
    When not in use it can safely be tucked back inside the frame space.
    In the below picture the quick fit outlet is currently connected to a USB outlet mounted on the dash so it serves a dual purpose role as a Sat Nav/Mobile phone charger outlet when riding and then a Charging port when in the garage. The USB outlet can easily be run under the Tank cover back to this point from the Dash. (2nd Pic)
    #34 sinewave, Dec 5, 2013
  15. GappySmeg
    GappySmeg Well-Known Member
    Sounds unlikely to only last 6 months. Having said that, it only takes one careless spell of over-discharging a battery (i.e. a couple of weeks laid up, with your alarm draining it) to knacker a battery. Keep them charged up and they'll last for ages, but over-discharge them and they'll never be the same again.
  16. GappySmeg
    or route the lead so the connector lives under the pillion seat... nice and easy to get to.
  17. sinewave
    Tried that one Gappy but the lead ends were too big to fit through any available holes leading through to the Batt area.
  18. samuk
    Thanks for that...i will get myself one..as my battery dies if i dont ride for a few weeks...its a pain..
    looking for a charger now...:D how much are they and do i need a particular type?
  19. GappySmeg
    Nope, mine didnt simply poke through either... there is a cross-member onto which the latching mechanism bolts. I had to remove said cross-member, route wire underneath, then re-attach the cross-member. 20 mins work, but well worth it.
  20. sinewave
